Plotting a 1D matrix in MathCAD 14 gives "this value must be real" error
6 replies · 8K views · last reply
Uku
Hello!
I'm having the following problem;
[PLAIN]http://www.hot.ee/jaaniussikesed/probleem_graafik.jpg
I try to plot a 1D matrice with a sequence, or a 1D matrice and I get a result that "this value must be real". Now... what!?
I am using MathCAD 14.
Help is much appreciated,
Uku
Uku
I see your matrix has an unspecified index "abi".
Remove the index "abi" from M, and it should work a lot better.
I'm assuming you want i to iterate over the values in M.
Also, if you want to do something with i in the definition of M, you need to make sure i is in the document before M, otherwise MathCAD will think i is the imaginary number sqrt(-1).
[Edit]How did you define i? Did you type i:1;12 (which is the proper way)?[/Edit]
If you really want, you can put an index "abi" in as just a name without symbolic function.
To do this I believe you need to type M.abi instead of M[abi.
  • Mathcad worksheet with constants k1, k2, k3 and initial concentrations cA0 to cE0, a Given block of five ODE-style equations, and Find solving for cA, cB, cC, cD, cE; F(10) evaluates to a 5-element column vector, with an empty red-bordered plot below.
dawidk89 said:
Hello
Help me !
My mathcad all the time show THIS VOLUE MUST BE REAL. This is my equation:
https://www.physicsforums.com/attachment.php?attachmentid=52208&stc=1&d=1350934907
THX for help
I can't see the entire plot to try and work out what you've done ... posting a worksheet as well as an image is generally helpful as several problems are not obvious from just a screenshot (also saves respondents typing things in). Try plotting F(10) against F(10), or assiging F(10) to a variable and plotting that using a standard range variable technique.
See attached Mathcad 11 format file.
Mathcad worksheet showing F(10) as a column vector of values 2.91, 1.91, 2.575, 2.09, 4.515, with two stem plots below: F(10) against F(10), and f10 against index i from 1 to 5.
