Plotting the approximation of the Dirac delta function
3 replies · 2K views
Lambda96
Plot ##g^{\epsilon}(x)## for ##\epsilon=1## , ##\epsilon=\frac{1}{2}## and ##\epsilon=\frac{1}{4}##
none
Hi,
I am not sure if I have solved the following task correctly
I did the plotting in mathematica and got the following
Would the plots be correct? What is meant by check for normalization, is the following meant?
For the approximation for ##\epsilon > 0##, does it mean that for the area of ## 0 < x < \epsilon## the area must be 1, so for the case ##\epsilon=1## the total area would be 1, the half for ## 0 < x < \epsilon## would then be ##\frac{1}{2}##, so the normalization constant should be 2?
To sketch usually means to draw by hand. Is this behavior that you expected? Look at the formula. Between minus epsilon and +epsilon, what is the function doing (does it change with x)?
Normalization refers to the area under the "curve" equal to 1 over the entire spectrum. Do these graphs satisfy that?
Yes, those plots look correct.
It means to check that the integral is 1.
No. It means that the area of ##- \epsilon < x < \epsilon ## must be 1.
No. No further normalization is needed. The area between each graph and the x axis is already 1.
Thank you scottdave and FactChecker for your help 👍👍
