Create Pneumatic Bicycle: High Torque or RPM?
  • Thread starter Thread starter Mesmerizer
    Bicycle Pneumatic
The discussion centers on the design considerations for creating a pneumatic bicycle, specifically debating the choice between high torque with low RPM versus high RPM with lower torque. Participants emphasize that low RPM with high torque may optimize compressed air usage and improve PSI efficiency. The need for high internal pressure and a variable displacement pump/motor is highlighted as essential for effective operation. Overall, the consensus points to the inefficiency of pneumatic energy storage in vehicles.
  • Understanding of pneumatic systems and their mechanics
  • Knowledge of torque and RPM dynamics
  • Familiarity with variable displacement pumps and motors
  • Basic principles of compressed air energy storage
  • Research designs for pneumatic bicycles available online
  • Study the mechanics of variable displacement pumps and their applications
  • Explore the efficiency of pneumatic energy storage systems
  • Investigate the impact of high internal pressure on pneumatic systems
Inventors, mechanical engineers, and hobbyists interested in alternative bicycle designs, particularly those focused on pneumatic systems and energy efficiency.
Mesmerizer
I wish to create a pneumatic bicycle but not sure if i should use high torque low rpm or higher rpm with lower torque.
I am thinking that a low rpm with high torque will use less compressed air and make better use of the PSI.
Welcome to PF.
What exactly is a pneumatic bicycle?
Does it simply replace the chain with pneumatics?
Does it operate a compressor / motor to store energy?
Does it have a fixed volume tank or in an inflatable bladder?
Have you looked for designs on the web?
I suspect you will need high internal pressure to get a solid drive.
If you want efficiency you will need a variable displacement pump / motor.
Welcome to the PF.
Pneumatic energy storage is not an efficient mechanism for vehicles. How many such vehicles do you see on the road right now?
  • · Replies 17 ·
  • · Replies 22 ·
