Pointers -->(makes integer from pointer without cast)
8 replies · 8K views
SnakeDoc
I am to write a program that has its user enter 100 character or less and determine if the line is a palindrome or not. I must use pointers one that starts at the beginning and one at the end of the array that must work their way in until they meet.(I'm also having trouble with this not sure how to keep them from going past each other.) As of now the program seems to be working just fine. When I compile the code I get the following warnings though.
:45:5: warning: passing argument 2 of 'is_palindrome' makes pointer from integer without a cast [enabled by default]
k = is_palindrome(j, letters[N]);
:20:6: note: expected 'char *' but argument is of type 'char'
bool is_palindrome(int n, char array[n]);
In function 'is_palindrome':
hw27.c:61:19: warning: assignment makes pointer from integer without a cast [enabled by default] while(arrayp1 =! arrayp2)
:65:25: warning: assignment makes pointer from integer without a cast [enabled by default]
if( arrayp1 =! arrayp2)
C:
//Preprocessor Directives
#include <stdio.h>
#include <stdlib.h>
#include <stdbool.h>
#include <ctype.h>
//define constants
#define N 101
//declare prototype
//call main function
int main(void)
  // Declare variables
  char letters[N]={'\0'};
  int i=0;
  int j;
  bool k;
  printf("Enter a message: ");
  while ((letters[I]=getchar()) != '\n')
[INDENT]  //if the array element is a letter then make it upper case
  if (isalpha(letters[I]))
[INDENT]  letters[I]= toupper(letters[I]);
  i++;
  j++;[/INDENT]
  }[/INDENT]
  if (k == false)
[INDENT]  printf("The line is not a palindrome.");[/INDENT]
  else if(k == true)
[INDENT]  printf("The line is a palindrome.");[/INDENT]
  exit(EXIT_SUCCESS);
  int i=0;
  int len = n;
  char *arrayp1 = &array[I];
  char *arrayp2 = &array[n-1];
[INDENT]  for(i=0; i<len; i++)
[INDENT]  if( arrayp1 =! arrayp2)
[INDENT]  return false;[/INDENT]
  n--;[/INDENT]
  }[/INDENT]
  return true;
Should be
while(arrayp1 != arrayp2)
not
Should probably be
bool is_palindrome(int n, char *array)
not
Using letters[N] is incorrect. That is equivalent to passing a single character, not an array of characters. You need to pass the pointer letters.
SnakeDoc said:
C:
  i++;
  j++;[/INDENT]
  }[/INDENT]
You are using I instead of i. Why to you have a j++ in there? What happens if the user inputs more than 100 characters?
SnakeDoc said:
C:
  if (k == false)
  else if(k == true)
If the first comparison (k == false) is not true, can there be any other possibilities than k == true?
Khashishi said:
Should be
Should probably be
not
bool is_palindrome(int n, char array[]) would also be valid.
SnakeDoc said:
C:
  i++;
  j++;[/INDENT]
  }[/INDENT]
This change in case is an artifact of the forum software. If you type "letters", the software things it is a BBCode italics tag, and changes it to and renders everything following it in italics, even inside a block with code tags.
@SnakeDoc, what is with the
tags in your code?
Also, while I'm at it, some of your comments look like they're there only because some comments are required.
For example //define constants is merely restating the obvious, that a constant is being #def -ined. A better comment would say what N is being used for.
//call main function is both useless and technically wrong. This is obviously the main function, but you aren't calling it -- this is the definition of main.
//Declare variables -- is also pretty useless. A good comment doesn't merely restate what the declaration or statement is doing, but should give some explanation of why this is happening.​
//if the array element is a letter then make it upper case -- This is a good comment. It explains why the code is doing what it is doing.​
o:)
DrClaude said:
o:)
There are several workarounds.
1. Don't use i as an array index.
2. If you use i as an array index, insert a space between [ and i, as in [ i].
3. Changing the color of the text for the index fools the system software so that it doesn't treat it as an italics tag. For example, arr. (You can't notice that the 'i' is a different color unless you use the BBCode editor.)
tags in your code?
The professor makes us comment all the code he has grad students correct our code and check to see if we have comments when ever I think something doesn't really need a comment for example the //Declare variables I seem to get docked points. The //call the main function thing is just what we were told to do at the beginning of the semester and has become a habit everyone's code in class has that in common. usually the lack of it causes us to get points docked.
Instead of //Declare variables, which is pretty useless, maybe do something like this:
C:
// Variable declarations
  char letters[N]={'\0'}; // Array that will hold the string to check
  int i;  // Loop control variable
  int j; // Not sure what it's being used for
In your code you increment j, without ever having initialized it. That's a real problem! You also have a variable k that you don't need.
C:
   if (is_palindrome(j, letters[]))
      // Do something
   else
      // Do something else
It's really silly. Every C or C++ program has a main() function. I don't think I've seen code in "the real world" where they have a comment on main(). Other functions, however, definitely should have explanatory comments. In any case, main() doesn't call itself, as your comment implies. main() is called from startup code that the compiler and linker insert into the executable.
I'm not at all saying to not use comments. What I'm saying is make an effort to make your comments useful.
