Badgerinapie
- 3
- 0
The problem is taken from A Modern Approach to Quantum Mechanics by Townsend, and is stated as follows:
The answer given in the back of the book is 0.12, though I have not managed to get this result.2.17. Linearly polarized light of wavelength 5890Å is incident normally on a birefringent crystal that has its optic axis parallel to the face of the crystal, along the x axis. If the incident light is polarized at an angle of 45° to the x and y axes, what is the probability that the photons exiting a crystal of thickness 100.0 microns will be right-circularly polarized? The index of refraction for light of this wavelength polarized along y (perpendicular to the optic axis) is 1.66 and the index of refraction for light polarized along x (parallel to the optic axis) is 1.49.
Classically, light traveling through a crystal of refractive index [itex]n[/itex] will pick up the phase factor
[itex]\phi = \dfrac{n \omega z}{c} = \dfrac{2\pi n}{\lambda_0}[/itex]
I couldn't see any obvious way of doing this with Bra-ket notation, which is odd since most of the preceding two chapters were spent building this notation up gradually; I'm probably missing something obvious. Instead I tried to calculate the intensity of right-polarised light the crystal as a proportion of the overall intensity. This classical result should equate with the probability of an individual photon being right-polarised.
The incoming light is angled 45° to the x & y-axes so the respective components of the electric field are given as
[itex]\begin{align}<br /> E_x &= E_0 \cos (\dfrac{2\pi n_x \Delta z}{\lambda_0} - \omega t) \\<br /> E_y &= E_0 \cos (\dfrac{2\pi n_y \Delta z}{\lambda_0} - \omega t)<br /> \end{align}[/itex]
where [itex]\Delta z[/itex] is the thickness of the crystal. This gives the overall phase difference between the two components upon exiting the crystal as
[itex]\Delta \phi = \dfrac{2\pi \Delta z}{\lambda_0} (n_x - n_y)[/itex]
Now, my reasoning gets a touch hand-wavey here. Right-polarised light is where [itex]\Delta \phi = \frac{\pi}{2}[/itex], and the sine function happens to be a maximum for this phase difference, so I'd expect [itex]\sin \Delta \phi[/itex] to give the component of right-polarised light(?). So, the proportional intensity of right-polarised light should be given by [itex]\sin^2 \Delta\phi[/itex].
But, plugging in the numbers in the question gives the proportion/probability 0.58, which is way off from the value of 0.12 given as a solution. So I suspect I have misunderstood something crucial about this question.
