Poll: For physics and math, Notebook vs Loose leaf papers
  • Thread starter Thread starter user079622
    University
The discussion revolves around the preferences for using notebooks versus loose leaf papers for taking notes in university-level physics and mathematics courses. Participants explore the advantages and disadvantages of each method, considering factors such as organization, flexibility, and personal learning styles.
  • Some participants express a preference for using a mixture of both notebooks and loose leaf papers, citing the practicality of loose leaf for adding or removing sheets as needed.
  • Others argue that notebooks help keep notes organized in one place, although they may limit the ability to mix topics.
  • Concerns are raised about the weight and bulk of carrying multiple notebooks versus the flexibility of a binder.
  • Some participants mention using specific types of pads or papers, such as engineering pads, for note-taking and organization.
  • A few participants highlight the importance of handwriting for retention and learning, contrasting it with electronic note-taking methods.
  • There are discussions about the potential downsides of using loose leaf, such as the risk of losing sheets or the need for additional organization.
  • One participant shares their experience of transferring notes from a notebook to printer paper for clarity and aesthetics.
  • Another participant mentions the historical context of note-taking methods, indicating that preferences may vary based on the era of study.
Participants do not reach a consensus on the superiority of notebooks versus loose leaf papers, with multiple competing views and personal preferences expressed throughout the discussion.
Participants note various factors influencing their choices, such as learning styles, organizational needs, and the specific requirements of their courses. The discussion reflects a range of experiences and preferences without resolving the underlying questions about the best method for note-taking.
At university, do you use notebook or loose leaf papers?
  • Notebook
  • Loose leaf papers
Results are only viewable after voting.
user079622
At university for physics and math, do you use notebook or loose leaf papers(binder,pocket etc)?
For Physics I mean any branches of physics(engineering, classical, quantum, etc...)
Explanation?
pros & cons?
Explanation?
pros & cons?
Both?
pines-demon said:
Both?
Yes, you can elaborate...
What does this count as?
https://www.amazon.com/NIB-NISH-9483991-LOOSELEAF-BINDER/dp/B002JESV24?tag=pfamazon01-20
I always used a mixture of both. Single notebooks are better to keep things tight in one place but I have always found that notebooks are single topic (I cannot mix EM and mechanics for example). However I found myself not always filling the notebooks and having too many is too much weight. A looseleaf binder is quite practical because you can remove or add paper sheets at will which is very practical if you do a lot of drafts versions of calculations and you do not want to carry everything with you. I somehow found myself using a mixture of both. I reserved notebooks for main courses which I knew that were worth it (but most of the time I did not know if it was the case beforehand).
pines-demon said:
I always used a mixture of both. Single notebooks are better to keep things tight in one place but I have always found that notebooks are single topic (I cannot mix EM and mechanics for example). However I found myself not always filling the notebooks and having too many is too much weight. A looseleaf binder is quite practical because you can remove or add paper sheets at will which is very practical if you do a lot of drafts versions of calculations. I somehow found myself using a mixture of both. I reserved notebooks for main courses which I knew that were worth it (but most of the time I did not know if it was the case beforehand).
Do you put out sheet of paper or write directly in binder?
Not have problems with missing the sheets?
Some people say ; why even take notes if we have books, so they only practice and do homework in notebook or sheets of papers(binder)..
I took the notes on paper pads (with pre-punched holes) and then tore them off, stapled them when the notes from the class took several pages, and put them in the binder. The pads were either Engineering Pads or simple Lined Pads, depending on how many figures were part of the lectures (so mostly Engineering Pads).
https://gatech.bncollege.com/School...cialty/ENGINEERING-COMP-PAD-GREEN-TINT/p/7905
@berkeman
Reason why you dont use notebook, lack of organization?
Usually aside, but if the binder allows it you can write on it.
That can be an issue, yes.
We can give you anecdotal evidence but you have to check what works on you. You can try different methods and see which one you prefer. Each method requires a different kind of organization.
I myself find that I can only learn by taking notes, so that's what I do. But different people find different techniques. Some people retain information better by listening attentively, some just retain what is written on the board, some take notes.
By notebook, do you mean like a lab notebook? I've used lab notebooks in my work (not in school), where I needed a legal record of my work for patent reasons. To document the work leading up to a patent, you need to have a notebook where pages can't be removed or added (hence the page numbers in the notebook), and important entries need to be witnessed and signed by co-workers who understand the work. It's a bit of a pain keeping a Table of Contents in such notebooks, since you have to reserve the first few pages for it and keep going back to add new entries into the ToC to keep track of where things are.
For school there are generally no such requirements, and the flexibility of being able to add and subtract pages, etc., was a big help. I could also keep my "crib sheet" for each class at the start of each binder section, and when I redid the crib sheet (which typically happened several times per semester, especially near the end of the semester when I was studying for finals), it was easy to substitute it into the binder.
I would typically have one binder per semester, with a binder section for each class in it.
A high quality mechanical pencil on printer paper. That's just how I rolled. Looks way more beautiful. I did assignments on printer paper. I took notes in class in a notebook, and then transferred them onto
printer paper. Every time I get done with a slide, problem, or topic. I would draw a horizontal line across the page. I got addicted to the sound it would make. And it would symbolize permanent retention in my brain.
user079622 said:
At university for physics and math, do you use notebook or loose leaf papers?
A blackboard.
This question depends a lot on which type of learner you are. I cannot remember things very well if I haven't written them down in some way, manually. Ok, when I studied there haven't been notebooks so I never had to answer this question. Nowadays, I use both, depending on speed and comfort. Particularly since TeX editors in combination with AHK enable me to be comparably fast.
However, if my goal is to learn something and keep it in mind, I still prefer handwriting over electronic content. I even do really like blackboards and I constructed a small one at home so that I can use one. The term looseleaf creates a bias toward notebooks in your question so your poll will be biased, too, and of little value. Nobody uses loose leaves. They use ring binders or booklets. And other than @berkeman's example above, I found them ranging between € 0.29 and € 3.17 (for documents). I think the basic difference is whether you can learn by just viewing things - not me - or you need to work it out. That's also the reason I do not like videos very much. They are nice to watch, you think you got the clue, and they are as quickly forgotten as they were started.
And last but not least: I have never heard of a looseleaf crash!
I mean on classic lined, grid or blank pages notebook.
But that is double job.
If you want to be beautiful you can use this romantic notebook.
fresh_42 said:
A blackboard.
How old are you?
How old are you?
Old enough to have experienced more than one hardware crash.
How old are you?
I was extremely particular. Those pages are brown. I need white. Pencil on white printer paper gives a stronger contrast. And. I really really need to have that horizontal line and the sound it makes. I feel these pages would tear. lol. And double work having to transfer it over? Nope. That is part of the study process. Copying it over does help with memory retention. I am primarily a visual learner. I can read the text book. Look at the slides. Just look with my eyes. All I really need. Recopying makes it look nicer for my visual learning. And it does engage the brain a little differently. Fascilitating commitment to memory.
user079622 said:
How old are you?
Rude question to ask here, some of us remember the days of cuneiform carving. :oldbiggrin:
  • Haha
We were so poor, we even hadn't a zero!
  • Wow
  • Haha
Is this still true? I haven't filed a patent since first-to-file became the law (America Invents Act 2013). I understood that this obviates much of that documentation,. but accentuates the need to file quickly.
That's a good question. The last patent that I filed through work was granted in 2011 (7,969,270 “Communication Transformer”), so things could well be different now.
Do you find easier to write on one sheet of paper then in notebook, because paper don't have thick edge that rubs against arm or you consider this irrelevant?
I mean on binders, pockets etc
Yes, nobody use sheets without storing them somewhere
user079622 said:
Do you find easier to write on one sheet of paper then in notebook?
I have a TeX editor, AHK with an appropriate script installed, and I use it a lot for quick calculations, preparing answers for the internet for its better preview function, as well as for my insight articles. I also use MSPaint and some mathematical graphing programs for occasional graphics.
I use the resulting pdf for searches in a browser, e.g. in my solution manual
https://www.physicsforums.com/threads/solution-manuals-for-the-math-challenges.977057/
if I want to find specific content.
I also have textbooks to look up things.
I have a classical Pelican pencil as well as a cheap $1 pencil with ink in reach, paper, and booklets for quick, short calculations, sketches, or combinatorial calculations like lists, enumerations, and similar.
In case I want to produce sustainable notes, I prefer @xTheFormlessOnedx 's method: pencil and printer paper in booklets or binders.
I have a small blackboard and chalk for brainstorming, and calculations I know I would wipe out parts a lot, or if I want - literally - a distant look at something.
Now tell me, what do you expect me to choose from your two possibilities? We live in times of opportunity. There is no need for either-or. Use both! Here is a post that summarizes that:
https://www.physicsforums.com/threads/how-to-use-the-w-in-www.1062388/
What is booklet, a few A3 folded on half?
Any reason why you dont use notebook?
No way, because I cant edit poll any more
I admit, I had trouble finding the correct English word for it. I mean things like these:
I use everything, a notebook, too. The machine as well as the paper version. With a TeX editor and especially with AHK I can type the complicated TeX commands pretty fast. I do not use handwriting on a notebook, I would never again look at them and my handwriting isn't very nice. If it had to be a machine I can as well write it nicely with a program.
And of course, there is always the human factor:
https://www.physicsforums.com/threa...at-numbers-and-corollary.992565/#post-6381538
@fresh_42
I used notebook and everybody around me, in all my school years I never ever see that someone use binder.
user079622 said:
Physicists use loose leaf because Newton did? :smile:
https://cudl.lib.cam.ac.uk/collections/newton/1
It is not the same thing to use binder/notebooks as a student than as a researcher. As a researcher you have manuscripts and drafts of your to-be-published work.
Does anybody knows why Newton wrote on single folded sheet instead on quires? (that mean every sheet must be sewed in Principia manuscript)
"The double foolscap sheets were not made up by the Writer in gatherings or quires but used singly.."
Preference or easier organization?
I think manuscript, codex or any book is sewed with few folded sheets(quires)
https://cudl.lib.cam.ac.uk/view/MS-ROYALSOCIETY-00069/5
  • · Replies 52 ·
9K
  • · Replies 42 ·
  • · Replies 60 ·
