High School Is Figure a Polygon? Examining Edges of the Image
The figure in question is classified as a polygon, specifically a self-intersecting polygon, which is not a "simple polygon." The middle line segment is counted as two edges, contributing to the overall structure of the polygon. The vertices are defined as A, B, C, D, and E, leading to potential polygon descriptions such as ABCBDECA or ABCEDCDA. For a shape to be considered a polygon, it must close the loop by returning to the starting point.
  • Understanding of polygon definitions and classifications
  • Familiarity with geometric concepts such as vertices and edges
  • Knowledge of self-intersecting polygons versus simple polygons
  • Ability to interpret geometric diagrams and notations
  • Research the properties of self-intersecting polygons
  • Study the differences between simple and complex polygons
  • Learn about polygon closure conditions and their implications
  • Explore geometric notation for describing polygons
Mathematicians, geometry students, educators, and anyone interested in the classification and properties of polygons.
Suyogya
Can someone please tell is this (https://ibb.co/stGFSKs) figure a polygon. If yes then is the middle line would count as an edge?
Mathematics news on Phys.org
Yes, it could be described as a polygon - but not a "simple polygon".
https://en.wikipedia.org/wiki/Polygon
If the left edge from top to bottom is A, B, D and the right edge from top to bottom is A, C, E:
Then this could be described as polygon ABCBDECA or ABCEDCDA.
Thus, it would be a polygon that intersects itself.
polygons that do not intersect themselves are called "simple polygons".
Oh, and to answer your follow-on question: The middle line segment would be two edges.
let be name the points as,(https://ibb.co/2srLjB1) if AC would be an edge then A and C are vertices and segments BC, AC, AD, CE became edges. Is this justified Also for a simple polygon there should be no self intersecting edge, the line AC just touches the lines BD and BE, is this sufficient to fulfill the intersecting condition?
.With your new point labels, the polygon would be either BACADECB or BADECACB.
In order for it to be a polygon, you need to close the loop - end at the same place you started.
I am not sure I am interpreting your statements correctly, but it doesn't sound as though you are following that rule.
To me, the question isn't answerable: either you define a polygon one way or the other, either allow straight angles or don't.
thanks for correcting
  • · Replies 16 ·
