Polynomial functions and calculating dimensions
13 replies · 3K views · last reply
euro94
Maria designed a rectangular storage unit with dimensions 1m by 2m by 4m. By what should he increase each dimension to produce an actual storage that is 9 times the volume of his scale model?
v= (1) (2) (4)
v= 8
v has to be 9 times larger
v= (x+1) (x+2) (x+4)
How do i find the value of x?
First thing, do you know what
(x+1) (x+2) (x+4)
should be equal to?
So the final volume is 134217728? or do you just do 8*9?
euro94 said:
Do you do 8^9?
nono, you do not take 8 to the 9th power.
Maria is simply trying to make the storage 9 times the original volume.
That is correct but I'm not sure you fully understood where you got the 8*9 from
Regardless, what I meant by
do you know what
(x+1) (x+2) (x+4)
should be equal to?
Was that this is incorrect.
If he wants the model to keep the same scale the ratio of the dimensions must still be 1:2:4
If you use (x+1)(x+2)(x+4), any x you put in there will change that ratio, take x = 1, then you'd get 2:3:5, which is not equivelant to 1:2:4.
How do you suppose we would go about changing the volume whilst keeping that ratio constant?
I'm not sure, change the values of (x+1)(x+2)(x+4)
That will not retain the scale of the box.
euro94 said:
ohhh or is it 72=(x)(2x)(4x)?
That is correct but I feel like you're just guessing at this point, do you understand WHY this is?
(x+1)(x+2)^2(x+4)^4
Where did you get this from?
Well i tried 72 = (x+4)(x+1)(x+2) and i subbed in 2, and it worked out.
