Polynomials and Calculating via mod7
  • Thread starter Thread starter silvermane
    Polynomials
7 replies · 3K views · last reply
silvermane
Working in (Z/7Z)[x], compute the greatest common divisor of the polynomials (X^2 - 3X + 2) and (X+6).
I need help understanding how to compute this. It would be greatly appreciated if someone gave me an example with different modulus and polynomials if at all possible.
Background: I'm in a class with a teacher who, well, talks to the board when he teaches. It's getting pretty bad (not to rant) and nothing he does gets through to the students. I'm thinking this is a fairly simple process too, so if anyone can help me with this, you're my hero! :)
You use the Euclidean algorithm.
Would it help you if I calculate the gcd of two numbers? The principle is thesame, just replace numbers with polynomials
Take 12 and 18. Perform long division on 18 and 12 to obtain that
18=1.(12)+6
So the remainder is 6. Now perform long division on 12 and 6 to obtain
12=2.6+0
The remainder is 0, so the algorithm stopts. The last non-zero remainder is the gcd: 6 in this case.
Let's do some polynomials in [tex]\mathbb{R}[x][/tex] this time: take x³+3x and x²+x (they always have to be monic, otherwise gcd is not unique). First perform long division to obtain
x³+3x=x(x²+x)+(-x²+3x)
The first remainder is -x²+3x. Now we perform long division on x²+x and -x²+3x to obtain
x²+x=(-1)(-x²+3x)+4x
The second remainder is 4x. Now we perform long division on 4x to obtain
x²+x=(x/4)(4x)+x
The third remainder is x. Now we perform long division on 4x and x to obtain
4x=4x+0
The fourth remainder is 0, so the algorithm stops. The last non-zero remainder was x and is the gcd.
I'm okay with doing the Euclidean algorithm, (though what you showed me was a wonderful refresher!) but I'm having trouble with the Z/7Z aspect of it. Where would that come into play?
So, using the Euclidean Algorithm, I obtained 56 as the gcd of (x^2 - 3x + 2) and (x+6).
56 is congruent to 0mod7, so would 0mod7 just be my answer?
No, 56=0 is already to late. You'll need the first non-zero polynomial to be the gcd.
Correct me if I'm wrong:
x²-3x+2=x(x+6)+(-2x+2)
This remainder is nonzero, so we continue (note that 1/2 = 4)
x+6= (-4)(-2x+2)+0
This remainder is zero, so the last non-zero remainder is the gcd.
Thus gcd(x²-3x+2,x+6)=-2x+2.
If you want the gcd to be monic (this is usual), then you will want to divide by -1 and obtain:
gcd(x²-3x+2,x+6)=x-1.
This seems to be right. Observe that x-1 = x+6 (mod 7).
It doesn't come into play in the Euclidean algorithm. It doesn't care what arithmetic is, just that it satisfies the property of a Euclidean domain.
The fact you're working in the polynomial ring over Z/7Z is only relevant to actually computing the results of arithmetic operations like division with remainder, subtraction, or testing for equality.
x+6= (-4)(-2x+2)+0
Yeah that's correct! I did my Euclidean Algorithm via matrices, and row reduced incorrectly, thus the 56! Thanks everyone for your extensive help! :)
