Positon and Momentum Wavefunctions: Normalizability?
MadMike1986
The position and momentum wavefunctions are Fourier transform pairs. If a particle has a perfectly defined position wavefunction Psi(x) = delta(x - x0), then what is its momentum wavefunction? Is this function normalizable?
Fourier transform relation (Can't figure out how to use the latex inputs to write this out)
I think I have to take the Fourier transform of a dirac delta "function"... I believe this is just a single frequency sine or cosine wave, but I only think this based on intuition from what the Fourier transform means.
As far as if this function is normalizable, I'm not really sure what is meant by that. Does that mean you take the integral over all space (or in this case all momentums) of the wavefuntion squared and set it equal to 1?
Any help/advice on this would be much appreciated. Its been a while since I've studied quantum.
Thank you.
You're basically right. The Fourier transform of the dirac delta will give a single momentum wave (an exponential with an imaginary argument), and the question as to whether it's normalizable is equivalent to asking whether it is square-integrable.
Thanks for the help.
The integral of (sin(x))^2 dx from negative infinity to infinity does not converge, therefore it is not square integrable and not normalizable.
My intuition is telling me that this means if you know the position exactly, then you can't know what the momentum is at all. Is this correct?
Your intuition is correct. The details you are showing are all wrong. The momentum wavefunction is a function of the momentum 'p'. Not the position 'x'. Why don't you actually try to find the momentum wavefunction corresponding to the position wavefunction delta(x-x0) and see if it confirms your intuition?
Dick is of course correct, and sin^2(p) isn't even the relevant function here. The Fourier integral is trivial and you should do it out.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
