Possible resistances using 3 resistors?
  • Thread starter Thread starter carnivalcougar
    Resistors
16 replies · 2K views
carnivalcougar
You have 3 resistors 1000ohms each. List all the resistances you can achieve using this set.
R in series = R1 + R2 + R3...etc
1/R in parallel = 1/R1 + 1/R2 + 1/R3...etc
If they are all in series you have 3000ohms. If they are all in parallel you have 333.333ohms. If two are in parallel while one is in series, you have 1500ohms. If one is in parallel while two are in series, then I'm getting that the Req will be 3000ohms. I'm not sure if that last part is correct. If it is, then the possible resistances are 333.33ohms, 1500ohms, and 3000ohms.
The resistance (for two series, one parallel) is not correct.
ehild
I don't think you can have 1 resistor in parallel with itself. So for the last one you have one in parallel with the 2 in series.
I meant connect one terminal of a resistor to the other terminal of the same resistor. Forming a circular resistor, effectively shorting it out of existence.
How would you calculate the resistance for two series and one parallel? I'm doing it as Req = R1 + R2 + (1/R3)^-1
I was responding to the OP's post lol. He was trying to have 'one in parallel with 2 in series' but what he was doing was having one resistor in parallel with itself ([itex]\frac{1}{R}[/itex]-1) or R+R+R which was wrong.
So two in series and one in parallel would be equal to R1 + (1/R2+1/R3)^-1 ?
So all in all you can have:
One resistor alone = 1000ohms
Two resistors in series = 2000ohms
Two resistors in parallel = 500ohms
Three resistors in series = 3000 ohms
Two in parallel, one in series = 1500ohms
Two in series, one in parallel = 1500ohms
All in parallel = 333.33 ohms
Is this all correct and am I missing any others?
Is not that two parallel and one series with the parallel ones? Look at the figure: What is the equivalent resistance ?
ehild
you are doing the same thing for both (2 in parallel, 1 series) so getting the same answer. did you see the link from my previous post? I thought it did a good job explaining it.
ehild
It looks like the Req would be 3000ohms
The link brought me to a picture of the cover of a Java textbook. However, isn't this two in parallel and one in series?
Wouldn't the Req of that be 1500ohms?
Wouldn't the resistance of this also be 1500ohms? (2 in series 1 in parallel)
http://www.cheng.cam.ac.uk/research/groups/electrochem/JAVA/impedance/figure/sparal1.gif
I think I see now. For two in series and one in parallel you need to find the Req of the 2 in series which is 2000ohms. Then you do (1/2000 + 1/1000)^-1 which is 666.67 ohms.
That leaves 7 possible combinations with three resistors:
Two in series, one in parallel = 666.67ohms
thats weird, when I see the image it is of a circuit! It must be a browser issue or something. I attached the image below that I was talking about (this link should work). anyway it looks like you already figured it out. good job.
http://s29.postimg.org/vtkoxgodz/combination.png
