Potential and E field for a non homogeneous charge Density
The discussion centers on the potential function V(x) for a non-homogeneous charge density, specifically addressing solutions to Laplace's equation. The derived potential for the region |x| ≤ a is V(x) = (a²/π²) ρ₀ sin(πx/a), while for x > a, the potential is expressed as V(x) = (aρ/π)x + (a²ρ/π). The boundary conditions lead to the conclusion that c = (aρ/π) and the necessity of a piecewise definition for the potential function is emphasized. The alternative potential form V(x) = (a²/π²) ρ₀ sin(πx/a) + kx + l is also proposed for consideration.
  • Understanding of Laplace's equation and its applications in electrostatics.
  • Familiarity with piecewise functions and their definitions.
  • Knowledge of boundary conditions in mathematical physics.
  • Basic concepts of charge density and electric potential.
  • Explore the derivation of solutions to Laplace's equation in different coordinate systems.
  • Study piecewise continuous functions and their applications in physics.
  • Investigate boundary value problems in electrostatics.
  • Learn about the implications of non-homogeneous charge distributions on electric fields.
This discussion is beneficial for physicists, electrical engineers, and students studying electrostatics, particularly those interested in solving potential functions for varying charge densities.
Diracobama2181
Suppose you have an infinite slab of thickness 2a has a volume charge density ρ(x) given by $$ρ(x) = ρ_0sin(πx/a) , |x| ≤ a$$, and
$$ρ(x) =0 ,|x| > a$$
where ρ0 and a are positive constants. The geometry of this
system is such that x = 0 is the central plane contained inside the slab with
the x−axis being perpendicular to it. In addition, take this plane to be the
potential reference plane; i.e., φ(x = 0) = 0. For the above charge distribution,
calculate the potential φ(x) and the electric field E(x) everywhere in space.
$$\nabla^2V=-\frac{\rho}{\epsilon}$$
Based on the conditions, I found that $$V(x)=\frac{a^2}{\pi^2} ρ_0sin(πx/a)$$ would be a solution to Laplace's equation for $$|x|\leq a$$
and $$V(x)=cx+d$$, where c and d are constants. From the boundary conditions, $$\frac{dV(a)}{dx}=\frac{a}{\pi} ρ_0cos(πa/a)=ac$$, $$c=\frac{a\rho}{\pi}$$ and $$V(a)=ca+d=\frac{a^2}{\pi^2} ρ_0sin(πa/a)$$, $$V=\frac{a\rho}{\pi}x+\frac{a^2\rho}{\pi}$$ for $$x>a$$ (a similar setup would find V(x) for x<-a). Does my setup seem correct? Also, wouldn't $$V(x)=\frac{a^2}{\pi^2} ρ_0sin(πx/a)+kx+l$$ also be a solution for constants k and l? Thank you.
You can't avoid a piecewise definition here. One function for the interior, one function for the outside, that is fine.
  • · Replies 19 ·
