Potential and Thermal Energy
The discussion focuses on calculating the fraction of potential energy converted into thermal energy during an inelastic collision between two railroad cars. The initial potential energy (PE) of the first car, which rolls down from a height of 20 m, is transformed into kinetic energy (KE) before the collision. The analysis concludes that half of the initial potential energy is converted into thermal energy during the collision, as the kinetic energy before the collision is equal to the potential energy, and half of that is lost due to the inelastic nature of the collision.
  • Understanding of potential energy (PE) and kinetic energy (KE) concepts
  • Familiarity with conservation of momentum principles
  • Knowledge of inelastic collisions and energy transformations
  • Ability to apply basic algebra to physics equations
  • Study the principles of inelastic collisions in detail
  • Learn about energy conservation in mechanical systems
  • Explore the mathematical derivation of kinetic energy loss in collisions
  • Investigate real-world applications of potential and kinetic energy transformations
Students studying physics, particularly those focusing on mechanics and energy conservation, as well as educators looking for examples of inelastic collisions and energy transformations.
PEZenfuego
Starting from rest, a railroad car rolls down a hill 20 m high and hits another identical car at rest. The cars lock together after the collision. What fraction of the first car's change in potential energy is converted into thermal energy in the collision?
ΔUth=mcΔT
Vg=mgh
K=(1/2)mv2
My basic strategy here was that kinetic energy will not be conserved (due to the inelastic collision) so I need to find how much kinetic energy was lost and then the "lost" energy can be attributed to thermal energy. I can use conservation of energy equations to figure out how fast the car is going before the collision (v1i)
ΔVg+ΔK=0
mgΔh+(1/2)mv1i2=0
mghi=(1/2)mv1i2
Momentum is conserved, so
mv1i+mv2i=
2mvf.
That means that (1/2)v1i=vf
Then basically, Ki=Kf+Uth Note here, that this is kinetic energy for a different portion of the problem
Uth=Ki-Kf
Uth=(1/2)mv1i2-(1/2)(2m)(vf)2
Uth=(1/2)mv1i2-(1/2)(2m)((1/2)v1i)2
Uth=(1/2)mv1i2-(1/2)(2m)(1/4)v1i2
Uth=(1/4)mv1i2Uth=(1/2)((1/2)mv1i2)
Uth=(1/2)(mghi)
Uth=(1/2)(Vg)
Anyway, I really feel as though I did something horrendously wrong here. Thanks for your time!
Think about the problem this way. Regardless of high high the hill is, the change in PE is changed into KE at the time of collision. So ask yourself, if a car of mass m at some velocity v collides with an identical car of mass m, what is the final velocity of the car. Actually, you have already derived this relationship. So ask how much the KE is changed based on the conservation of momentum.
So is it okay to consider the kinetic energy of the first car before and after the collision and the kinetic energy of the second car before and after the collision separately like I did?
The KE of the first car will be (1/2)mv^2 before the collision. What will be the KE of both cars after the collision? The difference should be the loss of KE during the collision. So the PE of the first car will be converted into KE at the time of collision, then the KE after collision will, hopefully, less than the KE before the collision. Now you can work the percentages.
That sounds like exactly what I did! So do you think my answer is correct?
"What fraction of the first car's change in potential energy is converted into thermal energy in the collision?"
I don't see your answer. I would think it should be something like 1/2, or 3/5. or...
I got 1/2. Sorry, it is there at the bottom, just not in words.
I don't think so. The initial KE is (1/2)mv^2. What is the final KE of the total mass (2m)? Now what is the ratio?
Remember that you have already calculated the velocity after the collision as it related to the velocity bvefore the colision.
Now I'm confused again :confused:
Okay, step by step. Follow along and tell me where my mistake is. Momentum is conserved. Kinetic energy is not.
Step 1: The potential energy of the car an Earth turns completely into kinetic energy of the car (ignoring kinetic energy of the earth).
Step 2:
mv1i+mv2i=mvf+mvf
Therefore, (1/2)v1i=vf
Step 3:
Kinetic energy before the collision: (1/2)(m)(v1i2)
Kinetic energy after the collision: (1/2)(2m)(vf)2
Now we plug in the equation we got from step 1.
(1/2)(2m)(1/4)(v1i2)
(1/4)m(v1i2)
Kinetic energy after the collision: (1/4)(m)(v1i2)
Step 4:
So, half of the kinetic energy is lost. Therefore, half of the kinetic is turned into thermal energy. Since the kinetic energy before the collision is equal to the potential energy, that implies that half of the potential energy is transformed into thermal energy.
I hope that makes sense. Where is my mistake?
OOPS, my mistake. I think you are correct, 1/2
Thanks for looking over it. One concern was that the height doesn't factor into this ratio. That seems a little strange to me, but I can accept it as true. This isn't necessarily a difficult problem, but it was difficult to keep track of the variables as there are essentially three stages to the problem rather than a simple before and after.
Regardless of the heighth, the change in PE will be converted to some amount of KE. Then you have to figure out the ratio of the initial KE and the final KE as you did.
  • · Replies 20 ·
