Potential difference and proton energy between charged parallel plates
  • Thread starter Thread starter metz143
    Idea
2 replies · 2K views
metz143
Potential Difference Problem..Help!
:smile: Problem: Two parallel plates having equal but opposite charges are separated by 12mm. Each plate has a surface charge density of 36.0 nC/m2. A proton is released from rest at the point near the positive plate.
Determine: The potential difference between the plates & the energy of the proton when it reaches the negative plate.
Thanks!...Merry Christmas! :confused:
I'd find the electric field first, and then use that to find the potential difference.
Assume each plate is an infinite sheet of charge. Do you know how to calculate the electric field due to a single infinite sheet of charge? You might have derived this in class already, or your textbook might have it... Or you can derive it yourself using Gauss' law.
Then see how the fields create by these two plates of opposite charges add together.
Since you have the field, you should be able to find the potential difference.
You should then be able to find the electric potential energy of the proton.
Merry Christmas! :smile:
Hi there,
I can understand why this problem may be confusing, but let me try to break it down for you. The first step in solving this problem is to calculate the electric field between the two plates. This can be done using the formula E = σ/ε0, where σ is the surface charge density and ε0 is the permittivity of free space.
Once you have the electric field, you can use the formula V = Ed to calculate the potential difference between the plates. Here, V represents the potential difference and d is the distance between the plates, which in this case is 12mm.
To find the energy of the proton, you can use the formula E = qV, where q is the charge of the proton (1.6 x 10^-19 C) and V is the potential difference that you calculated in the previous step.
I hope this helps and if you have any further questions, please don't hesitate to ask. Happy holidays! 🎄
