Potential energy of two masses connected by 3 identical strings
The discussion revolves around the potential energy of two masses connected by three identical springs, focusing on how to derive the total potential energy when the masses are displaced from their equilibrium positions.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • The original poster attempts to understand the derivation of the third term in the potential energy equation, questioning how it relates to the displacements of the masses. Participants explore the implications of spring compression and elongation based on the direction of mass movement.
Participants are actively engaging with the problem, offering insights into the potential energy contributions from the springs based on different scenarios of mass displacement. There is a recognition of the need to consider both compression and elongation of the springs, although no consensus has been reached on the exact formulation of the potential energy terms.
There is an ongoing discussion about the assumptions regarding the direction of displacement and how it affects the potential energy calculations. The original poster expresses uncertainty about the terms involved in the potential energy equation, indicating a need for further clarification.
mccoy1
Hi fellows,
'Two particles of mass m are connected by three identical springs of relaxed length l and constrained to move longitudinally. What is the potential energy when the two masses are displaced from their equilibrium positions?
What I know: let k = force constant of the strings, x1 and x2 be displacements of the masses, so:
P.E (V) = (k/2)x1^2+(k/2)x2^2 + (I know there is going to be a third term here but I don't know what it's)..
The book says that that third term is (k/2)[x2-x1]^2...how did they derive that? Any insight would be appreciated.
Thanks you all.
what do you think is the compression of the middle spring,
1/2(kx^2),right
where x is the cange in length of the middle spring ,that is (x^2 = (x1-x2)^2)
1/2(kx^2),right
Thanks for the help. I still have problem though. If that's a compression of the middle spring, then the two masses are moving towards each other( hence compressing the middle spring). How about if the two particles are moving in the opposite directions?
then it's the elognation, which will again lead to a rise in the potential energy of the spring
Great...so would it still be x2-x1 or x2+x1 this time?
one of the terms x1, or x2 will get negative
we are measuring them from their eqilibrium positions
this means that the equation holds for both the cases
and yes ,were x1 and x2 magnitudes of displacement only ,what you have put forth
would hol beyond doubt.
Great. Thank you for your time and help.
