Potential of ring with sphere inside it
7 replies · 4K views
adamp121
Hi,
I'm trying to find the potential of conducting grounded sphere with radius Rs which located in the center of charged ring with Rr (>Rs) with charge density λ, h meters up to the z axis (see the attached images)
Rs=4.3[cm]
Rr=6.6[cm]
h=13.1[cm]
λ=1.0[esu/cm]
The answer should be 0.81023024
2. The attempt at a solution
The sphere potential is easy one -
[itex]\Phi ring=\frac{2\pi Rr\lambda}{\sqrt{z^2+Rr^2}}[/itex]
But how do I get the potential of the sphere?
I've tried to use the image charged method, but I can't get to the right answer.
Can somebody help me?
Thanks,
Adam
Doesn't sound too hard :wink:. Am I missing something?
Can you give me some clue about the calculation of the sphere's potential?
I don't know how to calculate the sphere's potential but the problem can be easily done by method of image charges. Did you try that?
Yes.
I know how to replace a grounded sphere near to a single particle, but don't know how to replace a grounded sphere with surrounded ring.
I have only the ring’s potential on the Z axis, and it makes it harder.
Like a point charge, you can replace the grounded sphere with a ring here in this case.
adamp121 said:
I've tried it also, where I set the image ring with charge -
[itex]q'=-2/pi\frac{Rs}{Rr}[/itex]
Do you mean ##\displaystyle q'=-\frac{R_s}{R_r}Q## where ##Q=\lambda \cdot 2\pi R_r##?
[itex]R'=\frac{Rs^2}{Rr}[/itex]
Correct!
