Potential on an Infinite Strip
  • Thread starter Thread starter treynolds147
    Infinite Potential
The problem involves solving the Laplace equation, ##\nabla^{2}\Phi=0##, in a two-dimensional slab defined by the boundaries ##-\infty
  • Participants discuss the separation of variables method and the setup of the potential function. There is uncertainty about how to properly apply boundary conditions and evaluate coefficients. Questions arise regarding the implications of symmetry and periodicity in the potential function.
Participants are actively engaging with the problem, exploring the implications of their proposed solutions and boundary conditions. Some have suggested specific integrals to determine coefficients, while others have noted the importance of considering the periodic nature of the function. There is a recognition of the need to clarify the setup and approach further.
Participants are navigating the complexities of boundary conditions and the periodic nature of the potential function, with some expressing uncertainty about the correct approach to integration and coefficient determination.
treynolds147
A potential satisfies ##\nabla^{2}\Phi=0## in the 2d slab ##-\infty<x<\infty##, ##-b<y<b##, with boundary conditions ##\Phi(x,b)=V_{s}(x)## on the top and ##\Phi(x,-b)=-V_{s}(x)## on the bottom, where ##V_{s}(x)=-V_{0}## for ##-a<x<0##, and ##V_{s}(x)=V_{0}## for ##0<x<a##, and repeats periodically outside this window.
So this is clearly a separation of variables problem, and I'm splitting into two parts - one which treats the bottom boundary condition, and one which treats the top boundary condition (while the opposite condition is set to zero). However, I feel really unsure of what I'm doing. So far I have the potential in relation to the bottom BC as ##\Phi=\sum_{n}A_{n}\sin\frac{n\pi x}{a}\sinh\left(\frac{n\pi y}{a}\right)##. I make no claim that this is entirely right. I suppose I'm not entirely sure how to set up the general function in the first place, or how to evaluate the coefficients while taking into account the periodic nature of the BC. Any nudges to get me started on the right foot?
Your proposed potential will work fine for the full problem because of its symmetries, but not for the split problem where you put one of the boundary conditions to zero. Can you see why?
Once you have argued for that, you must fix the constants ##A_n##, what information do you have available for that?
I think I see why it'd work for the full problem. The sine term is going to give me something that falls on both the upper and the lower boundary, i.e. something like a square wave, right?
As far as fixing the constants is concerned, I know the condition that has to be met (i.e., that ##\Phi(x,-b)=-V_{s}## and ##\Phi(x,b)=V_{s}##. So it'd be a matter of doing an integral of the form ##\int V_{s}\sin\frac{n\pi x}{a}##, right? But the region of integration would have to be split into intervals depending on n to accommodate the changing sign of the constant as it varies from -a to 0 and from 0 to a, etc.
You only need to do the integration on one segment of the boundary since you have done a sine expansion.
Ah, I see, the sine already incorporates the periodicity. Let's see, calculating the coefficients then, we should have
##\int_{-a}^{a}V_{0}\sin\frac{n\pi x}{a}\,\mathrm{d}x=\int_{-a}^{a}\sum_{n}A_{n}\sin\frac{n\pi x}{a}\sinh\frac{n\pi b}{a}\sin\frac{n'\pi x}{a}\,\mathrm{d}x##,
which, if I did my integrals correctly, should give ##A_{n}=\frac{4aV_{0}}{n\pi}\frac{1}{\sinh(n\pi b/a)}##. And with the coefficients found, that should complete the potential expansion.
Yes, with the additional comment that it is enough to consider ##0 < x < a## as the sines are anti-symmetric just as the boundary condition. The addition of the range ##-a < x < 0## only doubles both integrals.
Ahhh, I see that now. Thank you so much for your help!
  • · Replies 19 ·
  • · Replies 20 ·
