Power Dissipated for 2 different circuits
To determine the ratio of R1 to R2 for equal power dissipation in circuits A and B, the currents through R2 must be set equal, leading to the equation (2EMF)/(2R1+R2) = (EMF)/[(R1^2/2R1) + R2]. The discussion highlights uncertainty about simplifying the equation by removing EMF, which is indeed constant. For part B, the condition under which power dissipated in circuit A exceeds that in circuit B is debated, with R2 > R1 being a proposed solution. Participants express confusion regarding calculations and seek confirmation on their findings, particularly when substituting values for R2.
lowcard2
Part A:
For what ratio of R1 and R2 would power dissipated by the resistor of resistance R2 be the same for circuit A and circuit B?
current for R2 of circuit A is (2EMF)/(2R1+R2)
current for R2 of circuit B is (EMF)/[(R1^2/2R1) + R2)
Part B:
Under which of the following conditions would power dissipated by the resistance in circuit A be bigger than that of circuit B? Choose the most restrictive answer.
R2<R1
R2>R1
R2<2R1
R2<.5R1
Equations used:
P = IV = I^2 x R = V^2 /R
Attempt:
I understand since R and P is same for both i only have to make the 2 currents equal.
(2EMF)/(2R1+R2) = (EMF)/[(R1^2/2R1) + R2)
I haven't taken physics or math class in 2 years so I'm kinda unsure on how to continue.
Since EMF is constant can I just remove it?
For part B just by plugging in numbers R2>R1 works but I am not certain
Diagram please.
totally forgot but here it is
deleting my post
if i can take out EMF and make R2 = 1 i come out with 4 as my answer. can anyone confirm?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
