Energy changes in a 75m waterfall and power from a turbine
  • Thread starter Thread starter penza
    Energy Power
13 replies · 3K views
penza
I have two questions
a)Water flows over a waterfall of height 75m of volume flow rate 6.0ms-1 and then lands in a pool below.
Outline the energy changes that take place
b)It is suggested that installing a turbine of the waterfall could provide a source of electrical energy. Estimate the power that might be available, stating one assumption that you make.
(The denstity of water= 1000 m-3)
Do you have any thoughts/ideas on this problem? You need to show your work to get help.
for sure i thought about it but i don't know...
Would you mind posting what you have done thus far? The guidlines of these forums state clearly that one should show one's work before receiveing assistance.
actually first i thought what energy transfer and i put 75/6 and but then i thought you just have to explain meaning that it goes from vaporisation to convection
What :confused: ?? I was thinking more along the lines of potential energy ---> kinetic energy?
ho yeh so actually the energy changes are from potential energy ---> kinetic energy, so that's actually the answer...
thank you
Hootenanny said:
What are your thoughts for question (b)...?
for question B i thought that because they have to install a turbine, looking that the density of water is 1000 than you have to do 1000/6 which is the flow rate so then to find the estimated power
You have just basically rephrased the question there :rolleyes: . Here's a hint: Think about mass and the relationship in question (a).
yeh but what do you to find the power
HINT Power is the rate at which energy is transfered;
[tex]P = \frac{dE}{dt}[/tex]
ok got it thank you
