Power Needed to Accelerate 1200 kg Car from Rest to 20 m/s
The problem involves calculating the average power required for a car with a mass of 1200 kg to accelerate from rest to a velocity of 20 m/s over a period of 6.0 seconds. Participants are exploring the relationship between work, kinetic energy, and power in this context.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster attempts to calculate the force and work done but questions their results when the calculated power does not match the provided options. Some participants suggest focusing on kinetic energy to determine the work done during acceleration.
Participants are actively discussing the calculations related to kinetic energy and power. There is a recognition that the work done corresponds to the kinetic energy gained, and some participants express confidence in the calculations leading to a power value of 40 kW. However, there is no explicit consensus on the correctness of the final answer.
Participants are navigating the definitions of work and kinetic energy, as well as the implications of using average power in their calculations. The original poster's confusion about the relationship between force, work, and power is evident.
wolves5
A car with a mass of 1200 kg accelerates from rest to 20 m/s in 6.0 seconds. What average power must the car produce to cause this acceleration?
a. 5 kW
b. 15 kW
c. 30 kW
d. 40 kW
For this problem, I did (1200)(9.81) and got the force. Then I used d= (6 seconds) x ((0 +20)/2) to find the distance. I got 60 meters as my distance. I then did force times distance to get the Work. Then I divided the Work by 6 seconds because that's how you get power. I got an answer that was none of the options above. What am I doing wrong?
The weight of the car is not the force doing the acceleration (unless of course it's fallen off a cliff!).
The work done while accelerating the car goes into giving it kinetic energy, expressed as velocity. If you know the velocity at the end of 6.0 seconds you should be able to calculate the work done; what's the kinetic energy for mass 1200kg moving with velocity 20 m/s?
The kinetic energy is 240000 J.
Do you divide 240,000 by 6 seconds? I got 40,000 Watts when I did that which is 40 kW. So is it D?
You've already stated that average power is given by work done divided by the time over which it is done. So you should have confidence in your result.
So the kinetic energy or the 240,000 J was the Work?
  • · Replies 20 ·
