Power set P(S) with symmetry difference.
The discussion centers on determining the orders of elements in the power set P(S) using symmetric difference Δ. Participants clarify that the order of an element A in this context is defined as the smallest positive integer k such that A Δ A Δ ... Δ A (k times) equals the identity element, which is the empty set ∅. The conversation emphasizes that A Δ A results in the empty set, indicating that the order of A is 2, as it takes two applications of the symmetric difference to return to the identity.
  • Understanding of power sets and their properties.
  • Familiarity with symmetric difference operations in set theory.
  • Knowledge of group theory, specifically the concept of the order of an element.
  • Basic set notation and operations.
  • Study the properties of symmetric difference in set theory.
  • Learn about the structure of groups and the definition of the order of an element.
  • Explore the concept of identity elements in algebraic structures.
  • Investigate the implications of power sets in group theory.
Mathematicians, students studying abstract algebra, and anyone interested in set theory and group theory concepts.
mikael27
Determine the orders of all the elements of the power set P(S) of a set S with symmetric difference Δ.
If A,b are two elements of the power set
the symmetric difference is
AΔB = (A-B) U (B - A)
How are we going to find the order of the elements?
What's AΔA? That's A^2 with your group operation.
its A Δ B not A Δ A.
I don't know how to start this
You would if you paid some attention to me. The order of A is the number of times you have to take the symmetric difference of A with itself to get the group identity. What's the identity of your group?
the identity is the empty set.
ok, now: what is A-A?
and therefore, what is (A-A) U (A-A) = AΔA?
I also know that AΔB = (A-B) U (B - A)= (B-A) U (A - B)=BΔA
well, that's very nice, but:
in a group, the order of an element g is the smallest possible positive integer k such that gk = e.
what is gk? it's g*g*g*...*g (k times).
so when calculating order of an element, you don't need to look at "other elements".
in the group you are considering, we are using "A" instead of "g", and "Δ" instead of "*".
so Ak = AΔAΔA...ΔA (k times).
there's no need to bring up "B".
To the answer is that we have one element A and the order of A is k?
Once again. What is AΔA?
Its A^2
mikael27 said:
Its A^2
Ok, yes, but what is that? What elements are in that set?
just A and A ?
mikael27 said:
just A and A ?
Use your definition! AΔA = (A-A) U (A-A). What is that? It's a very simple set.
it says that the A-A union A-A. On sets if A-A=0 it means it is zero
A-A isn't 0, if you mean the number zero. Do you know what A-A means? It's a set, not a number.
can you please explain me
A-B means the set of all the elements of A that are not in B. What is {1,2,3,4}-{5,4,2,7}? Now what is {1,2,3,4}-{1,2,3,4}?
yes i know that that's why i told you 0. There are no elements left
{1,2,3,4}-{5,4,2,7} 1,3
{1,2,3,4}-{1,2,3,4} no elements
And what do you call a set that contains no elements? That's what Dick is asking.
That's good. 0 isn't a good answer. 'empty set' or {} or ∅ is the way to say that. So A^2={}. What does that tell you about the order of A?
so A^2=empty set. no elements from -infinity to + infinity
That has nothing to do with the question I asked you. What does A^2={} tell you about the order of A? What's the identity of P(A)? Try to focus, ok?
i don't know
infinity order
You said, back in response #5, that "the identity is the empty set."''
Of course, "is" is symmetric! "The empty set is the identity". So, calling the identity "e", A\Delta A= \phi is the same as A\Delta A= e.
Now, what does that tell you about the "order" of A?zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
mikael27 said:
infinity order
I want to you reread Deveno's explanation in post 8. Look up what the 'order of a element in a group' means in your textbook or on line. Figure out why P(A) is a group under Δ. Then think about it for a while, come back here and explain to me what it means in your own words. Then if you still don't know we can continue.
Mikael, you're giving me the impression that you don't really want to think about the question. This forum is not for spoonfeeding you or giving you the answer without effort.
If you continue to do no effort then this thread will be locked.
  • · Replies 24 ·
