Practical for a civilian to build a space suit?
The discussion revolves around the feasibility of a civilian constructing a space suit for survival in a hypothetical scenario where Earth is separated from the Sun, resulting in a significantly reduced atmospheric pressure and extremely low temperatures. Participants explore various design considerations, materials, and the practicality of such a suit for limited outdoor exposure.
  • One participant questions whether a technologically savvy individual could build an insulated suit to withstand -150°C temperatures at 50% atmospheric pressure.
  • Another suggests using multiple layers of thick cloth, with potential joint designs to allow for movement, and proposes a heated blanket effect for warmth.
  • Some participants argue that at 0.5 atm, the suit may not need to be pressurized, while others highlight the challenges of maintaining heat in such conditions.
  • There is mention of using materials like down insulation and the need for a system to heat air to prevent freezing in the lungs.
  • One participant references the possibility of purchasing a used space suit from manufacturers, while another questions the validity of this claim.
  • A later reply discusses potential plot holes in the original scenario, suggesting that in a highly advanced society, individuals would not likely need to create their own survival suits.
  • Another participant recalls a similar narrative from a short story, indicating that this concept has been explored in literature before.
Participants express differing views on whether the suit needs to be pressurized and the practicality of constructing such a suit. There is no consensus on the best approach or materials, and the discussion remains unresolved regarding the feasibility of a civilian-built suit in the described conditions.
Participants highlight various assumptions about atmospheric conditions, temperature effects, and the technological capabilities of individuals in the scenario. There are also references to existing literature that may influence the discussion's context.
CCWilson
This is for a novel I'm writing. In it, the Earth has been separated from the Sun. At this point there is still an atmosphere (at perhaps 50% of normal pressure) but the temperature has fallen to somewhere around -150 centigrade. My question is this: Could a technologically savvy private citizen, after research, with a year's warning, build an insulated suit that would allow him to be outside for several hours? If so, what form would the suit take?
I'd probably think of multiple layers of thick cloth with some of the outer layers epoxied together, but it would restrict movement at the joints. The joints I'd probably think of some kind of metal slippage with a rubber-like seal, similar to the rubber you see on windshield wipers.
That's what I come up with from thinking about it for a few minutes. But one thing I don't know - is it even necessary to pressurize the suit against 0.5 atm pressure? It might be sufficient to develop a highly insulated suit. This I think would be much simpler, as you could epoxy the outer cloth layers in segments such that the joints aren't restricted, and you could add a wiring system to the bottom layer to create a "heated blanket" effect that would be nice and toasty, with battery power of course. And obviously a ventilation system would be necessary, but that's pretty trivial I think.
At 0.5 atm, there are many moredifficult challenges than making a space suit.
At 50% of normal atmospheric pressure, the suit doesn't need to be pressurized!
At the time in question, the individuals are living underground and need a way to work and travel above ground for a few hours. The suit - which wouldn't need to be pressurized at half normal atmospheric pressure - would have to be pressurized later when the oxygen and nitrogen liquify, and at that point an oxygen supply would have to be carried, and the underground bunker would have to be pressurized.
Very practical actually
you don't need a space suit for this, people go to everest with just oxygen masks (~1/3 the pressure on the surface at 0m).
I recommend doing research on thermal materials (emergency foil blanket is a good place to start) and Scuba systems as well as CO2 scrubbing. Also a good starting point would be to build an underground base complete with hydroponics and what not. Good research material would be Mars bases and what not.
As for the suit i recommend you watch this :http://www.parabolicarc.com/2010/01/09/video-dava-newman-shows-flexible-spacesuit-design/
I really look forward to your novel, I am a sucker for a post-apocalyptic story :smile:
Long term survival of the human race without Earth would be far more complex; see the discussion in this thread https://www.physicsforums.com/showthread.php?t=625503
CCWilson said:
The suit - which wouldn't need to be pressurized at half normal atmospheric pressure - would have to be pressurized later when the oxygen and nitrogen liquify [...]
More detailed explanation, please.
Mountain climbers use low-tech goose and duck down. Use enough to look like the Michelin man, that might do it. Boots with cork soles a foot thick, maybe. You'd need some way to heat the air so it didn't freeze the lungs.
You seem to be missing the -150°C stipulation, that's 100° lower than the coldest place on Earth! I may be wrong here but a space suit has the advantage of the vacuum for insulation, in an atmosphere at half pressure convection and conduction will make it harder to maintain heat. In otherwords on the heat issue alone this may be harder than a space suit.
You know, you could just buy one, from the folks who manufacture them for NASA. I don't have the link, but on a forum, a scientist familiar with government/industry commerce said that the manufacturing outfit would only charge $10,000 or so for a suit if you're a citizen, versus a million for NASA :eek:.
That doesn't sound right at all. Are you sure they aren't just selling off used ones as novelty items?
Hmm...thinking on this more it occurs to me that this scenario represents a significant plot hole in your story. Correct me if I'm wrong but your setting is:
- Due to an as yet undetermined catastrophe (black hole into sun, Earth flyby of massive object etc) the Earth is due to lose most/all the energy from the sun. This will result in temperatures plummeting until the Earth is back to something resembling the snowball of its early life.
- With the remaining decades/century left to them the peoples of Earth pour trillions of dollars and billions of manhours into the research and development of sustainable closed ecosystems and socioeconomic models so as to build minimally/optimally populated, self sufficient cities.
- Once research starts hitting deployable level they build/retrofit cities capable of keeping a few million people alive each even without the sun.
So long as I haven't got the wrong end of something the reason why I think this set up precludes your scenario is that in this situation there are not amateur survivalists. It's just not possible. You either live in one of the extremely high tech (note that does not necessarily mean nice to live in socially or aesthetically) cities maintained by their large population of specialist workers required to keep the technology/industry/ecology going or you're dead. If someone from the city needs to go outside they can use an extreme survival suit built in the city's internal factories. I can't think of a scenario where someone would have to cobble together bits and pieces to make their own.
Somebody wrote this exact novel a long time ago. I can't remember the name of the novel or of the author. Synopsis: The Earth somehow became separated from the Sun. The atmosphere eventually froze. Almost everyone died. The book tracked one family that survived. They used layers and layers of blankets for insulation. These layers and layers of blankets also kept the air in their house from bleeding out too quickly. They had to occasionally venture outside in leaky home-made space suits to dig for water, oxygen, and nitrogen in the frozen-out atmosphere and to dig for food at a grocery store that escaped the worst of the apocalypse. At the end of the novel they were found by scientists who had the technology to build a sealed environment, make real space suits, etc.
Found it. It was a short story, not a novel. A Pail of Air written in 1951 by Fritz Leiber.
Ryan, the reason that our hero needs to build (or buy) a sort of space suit is that he and his family weren't selected as residents of the city. He buys property close to one of the cities and digs a hole and somehow (details to be worked out, but probably involving a generator and fuel hoarding plus canned food) manages to keep his family alive for six months or so, with a plan to trek to the underground city and show his pitiful entourage to the city's external cameras (originally necessary to prepare for the possibility of non-residents storming the barricades) in hopes that they need his particular skill set or let them in out of Christian charity.
Fair enough.
Ryan, thanks for that link to the short story. Very cool. Of course by the time the oxygen had frozen or liquified, a pressurized space suit would have been necessary to go outside. And geothermal power - which was just becoming reality in 1951 - is a better choice than nuclear for the long term.
One thing I'm still trying to clarify is what the surface would be like after the temperature drops enough to liquify and then freeze oxygen and nitrogen. My guess is that oxygen and nitrogen would flow like water when they liquify, seeking lower levels, perhaps collecting into rivers that reach the oceans, if snow and ice didn't impede them. So maybe there wouldn't be a thick layer of liquid or frozen gases everywhere. I'm having trouble figuring out what sort of scientific discipline might have already worked this out.
Out of curiosity can you think of a believable reason they would not get let in? I'm struggling...
I can't speak for Russia but all space suits used in the United States were made by civilians! Perhaps you mean something else?
With five years or so warning, there would be a limit on how many underground cities could be built. So only a portion of the total population could be supported by the infrastructure. A lot of people would try to gain admission to the cities once the Earth was no longer in the solar system and the cold started to get severe. Initially the cities simply couldn't afford to let in people who didn't have a ticket, or the chances for survival for everybody would be diminished. At first they would turn everyone away who begged to get in, heart wrenching as it would be. But after a few months, they would no longer be in danger of being overrun, so those who had survived and were able to get to the bunker would probably be welcomed.
What I was asking was whether an individual person not associated with an engineering firm would be able to build outfits for his family that would allow them to walk around and breathe for several hours at temperatures well below -100 C.
That's pretty much what I was thinking, given that this is very likely one of the only few solo survivalists there's little danger in letting them in.
How flexible are you on the time scale by the way? 5 years seems nowhere near enough. That might be just about enough time to work out what options should be researched but given the huge amount of R&D required still I don't see any chance of completion within decades.
The shorter the time frame, the more dramatic the situation, the fewer people who could be saved, the more concentrated the mental processes. It would be tight, but the mechanical construction of the underground cities would be relatively straightforward, and the hydroponic farms would draw on existing experience. There has been enough research on biospheric living and terraforming that I think the recycling of resources would be doable.
I'm not certain how much lead time an approaching black hole would give us in reality. I suspect that we would notice some deviations in the locations of objects in the Kuiper Belt as it passed through, which would put us in the general five year range. I don't know whether we would notice its passing through the Oort Cloud. I definitely didn't want warnings on the order of hundreds of years, which would be the case with a rogue star heading our way.
If I remember correctly the first high altitude suits and perhaps spacesuits were not pressurized. They were kind of like super spandex that applied pressure to the arms, legs and torso. The reason is, that pressurized spacesuits were difficult to make and still retain flexibility. Moving your arms or legs inside a pressurized spacesuit was kind of like bending a long balloon.
Only time for a quick post but 1) hurrying cities seems pointless and a massive waste of resources. Just build sealed ones on the surface capable of taking the weight of frozen atmosphere. 2) you need to seriously look into closed ecological systems. There has never been a successful one and we don't have a good understanding of how to do it. It's not just a case of growing food! We require an ecology for everything from the development of our immune systems (growing up in a bubble will lead to severe allergies and probably death) to the processing of soil for nutrients.
Also whilst I appreciate the need for tension a line must be walked between tension and believability (aside from the technological hurdles the social disruption is likely to be a massive headache for starting such a project). For inspiration I'd recommend the short story Meela's flowers by al Reynolds; essentially a society equivalent in technology to our 1930s is told that they have 70 years before their sun is destroyed. The main character (from a more advanced society) prints of a range of technical documents from his ship and gives them to them so that they can build their technology base and industry to the point where they can evacuate the planet. The protagonist then spends the story in and out of stasis skipping forwards a few decades as a time to track process. The tension is high throughout and their development (along with their hurdles) very believable.
  • · Replies 25 ·
  • · Replies 21 ·
  • Sticky
  • · Replies 48 ·
71K
