Pressure in Mouth: Calculate Using ρgh
  • Thread starter Thread starter johnhuntsman
    Pressure
The discussion revolves around calculating the pressure in the mouth when sucking fluid from a straw submerged in a liquid with a density of 1500 kg/m³. The correct formula to determine the pressure is p = patm - ρgh, where patm represents atmospheric pressure, ρ is the fluid density, g is the acceleration due to gravity, and h is the height of the fluid column (0.25m in this case). The participants clarify that the pressure in the mouth decreases when sucking, leading to fluid being drawn up the straw, and that the height should be measured from the new fluid level in the beaker.
  • Understanding of fluid mechanics principles, specifically pressure calculations.
  • Familiarity with the equation p = ρgh for hydrostatic pressure.
  • Knowledge of atmospheric pressure and its role in fluid dynamics.
  • Basic grasp of how changes in pressure affect fluid movement in a straw.
  • Study the implications of Bernoulli's principle in fluid dynamics.
  • Learn about hydrostatic pressure and its applications in real-world scenarios.
  • Explore the effects of atmospheric pressure on fluid behavior in various contexts.
  • Investigate the mechanics of suction and how it relates to pressure differentials.
Students in physics or engineering, educators teaching fluid mechanics, and anyone interested in understanding the principles of pressure in liquids and gases.
johnhuntsman
There was a question on a quiz I just took and I want to make sure I got it right.
Something like:
"A beaker filled with to 2/3 its height with a fluid of density ρ = 1500kg / m3. You place a straw in the fluid such that the fluid in the straw is at a height equal to that of the fluid prior to having a straw put in (i.e., the height of the fluid is still 2/3 of the max height). You suck the fluid in the straw up 25cm. What is the pressure in your mouth?"
After a good while of trying to overthink it (using Bernoulli's principle) I figured that it would just be ρgh = (1500kg / m3)(9.81m / s2)(0.25m). Is it right or wrong? It may very well be the difference between an A and a B so it'll just kill me to not know 'til I find out my grade Monday.
What is the pressure in your mouth when it is open?
When you are holding the liquid up by sucking, is the pressure more or less, and by how much?
Shouldn't it be atmospheric pressure?
I would imagine there'd be more.
I suppose p = patm + ρgh should've been the answer then?
Hmmm. So would it be less if you were to blow instead?
Nevermind I suppose it'd be the other way around. Fluid would be sucked in (as air would be) because the pressure in the mouth is less. So that leaves me at a complete loss as far as what the answer is concerned.
Would it be patm - ρgh? ρgh being the change in pressure necessary to bring up that fluid 25cm?
Yes.
Provided the 25cm is measured from the new fluid level in the glass not the original level.
CWatters said:
Yes.
My teacher did say not to take change in original fluid level into account, but I gotcha. Thanks, I appreciate it.
