What is the Principle of a Capacitor?
  • Thread starter Thread starter Krushnaraj Pandya
    Capacitor Principle
The principle of a capacitor involves the interaction between two metal plates, where one plate (A) is charged by a voltage source, while the other plate (B) remains uncharged. When plate B is brought near plate A, electrostatic induction occurs, resulting in negative charge on the left face of plate B and positive charge on the right face. The discussion emphasizes the importance of understanding the connection of plate A to the battery's terminals, as this determines the charge distribution. Specifically, if plate A is connected to the positive terminal, it indicates a deficit of electrons, leading to positive charge accumulation.
  • Understanding of electrostatics and charge distribution
  • Familiarity with basic electrical concepts, including voltage sources
  • Knowledge of electron flow and current conventions in electronics
  • Ability to interpret capacitor principles and configurations
  • Study the concept of electrostatic induction in capacitors
  • Learn about the role of voltage sources in charging capacitors
  • Explore the conventions of current flow in electronics
  • Investigate the mathematical equations related to capacitors and electrostatics
Students studying physics or electrical engineering, educators explaining capacitor principles, and anyone interested in understanding electrostatic phenomena in electronics.
Krushnaraj Pandya
I was reading through the principle of a capacitor and I am unable to understand one of the statements. My textbook says the following-
Consider an insulated metal plate A. Let it be connected to a voltage source and charged to a maximum. Now an uncharged plate B is brought near it. Due to electrostatic induction negative charge is introduced on the left face and positive charge on the right face.
2. Homework Equations
All electrostatics related formulas.
Since plate A is connected to a voltage source, electrons travel from the source to the plate till both are at equal potential. Since plate A has a negative charge it should attract positive charge and thus induce positive charge on the left face and negative on the right of plate B. Where am I wrong?
We need to know if your textbook shows plate A connected to the positive terminal of the battery, or whether it shows plate A connected to the negative terminal of the battery.
it shows nothing. Just this text is written under the heading principle of a capacitor.
let me attach the photo of the paragraph.Pardon the camera quality, I have no other camera except my webcam.
If plate A is connected to the positive terminal of a battery then to say plate A is "charged to a maxium", means it has the maximum positive charge possible - which means plate A has a deficit of electrons, not a surplus of electrons. Perhaps that is what your textbook wants to describe.
In electronics, there is the awkward situation that its mathematics uses the convention that (positive) current flows from positive potential to negative potential. In actuality, the net flow of electrons is from negative potential towards positive potential.
alright, got it. Thank you very much.
  • · Replies 18 ·
