Probability density of a needle
11 replies · 5K views · last reply
user3
A needle on a broken car speedometer is free to swing and bounces perfectly off the pins at either end, so if you give it a flick it is equally likely to come at rest at any angle between 0 and pi. If the needle has a length r, what's the probability density ρ(x) of the x-coordinate of the needle point - the projection of the needle on the horizontal line?
Answer: 1/(pi r sin(theta) ) = 1/(pi r √(1-(x/r)^2 ) )
I can't see why the answer is not simply 1/2r. The shadow of the tip of the needle is equally likely to be seen at any point from -r to r
That is just an opinion, and it's wrong. It's more likely to be seen near the ends. It's equally likely to appear anywhere on the semicircle descibing the dial. It's x coordinate is more likely to be near the ends, since the semicircle has more length near the ends than it does in the middle.
Ok, could you please tell how to attack problems such as these effectively ?
Work it out from first principles. Don't "guess". Probability---especially---is one of those subjects in which untrained intuition is often wrong.
I don't much like the way this problem is stated. The one "firm" piece of information you are given is that "it is equally likely to come at rest at any angle between 0 and pi". But then you are asked "what's the probability density ρ(x) of the x-coordinate of the needle point?" which makes no sense. There is NO "x- coordinate" on a speedometer! Even the explanation, "the projection of the needle on the horizontal line" is ambiguous. Are we to take "0" at the center point, the pivot for the needle or at the left end?
Assuming we are to take the 0 point at the center, just because that is simplest, then the horizontal line is the "near side" of a right triangle with angle [itex]\theta[/itex], the angle the needle makes with the horizontal, and hypotenuse of length r. The length of that horizontal is [itex]r cos(\theta)[/itex]. Further since that angle is "equally likely" to be anywhere between 0 and [itex]\pi[itex], its probability density is [itex]d\theta= (1/\pi)dt[/itex]. Now with [itex]x= r cos(\theta)[/itex], [itex]dx= -r sin(\theta)d\theta= -(r/\pi) sin(\theta) dt[/itex]. From [itex]d\theta= (1/\pi)dt[/itex] we get [itex]dx= -(r/\pi) sin(t/\pi)dt[/itex].[/itex][/itex]
user3 said:
I am sorry. here's the full problm statement. Now please tell me if we can deduce rho of x directly without having to use rho of theta ! https://www.physicsforums.com/showthread.php?t=372696
No, you can't! This statement that the needle is equally likely to come to rest at any angle is all that you know about the probability distribution. If you don't know that, then you don't know anything.
You want something that is not possible! What you know is that there is a relationship of the form ##X = h(\Theta)## between the random variable ##X## = horizontal location of needle's point and ##\Theta## = angle of needle. You are told the probability distribution of ##\Theta##, and you can figure out the function ##h##. From that you can deduce the probability distribution of the random variable ##X##. This is a standard "change of variable" problem in probability, and it is, basically, the only way to do the question.
Thank you all. I guess my problem was that I thought calculating probability density depended mainly on intuition.
Probability is the area in which "intuition" has led more professional mathematicians astray than any other subject. Intuition can be dangerous until you have built up a solid encyclopedia of facts about the field---in other words, until you have 'trained' your intuition.
