Probability of Reaching Room Q in n Seconds
  • Context: MHB
  • Thread starter Thread starter jacobi1
    Challenge Probability
The discussion revolves around calculating the probability of a ball reaching room Q from room P in a network of rooms over a specified number of seconds, n. The problem involves understanding the movement of the ball between adjacent rooms and the implications of the parity of n on the probability of reaching room Q.
  • Some participants clarify whether the probability should account for the ball having visited room Q previously or only reaching it for the first time.
  • One participant notes that if n is odd, the probability of reaching room Q is 0 due to the unshaded nature of rooms P and Q.
  • Assuming n is even, a participant details the transition probabilities, explaining that the only way to reach Q in two moves is via a shaded room, leading to a calculated probability of 1/6 for that scenario.
  • Another participant presents a matrix representation of the transition probabilities and derives a formula for the probability of being in room Q after an even number of moves, specifically $\dfrac{2^{n/2}-1}{3\cdot 2^{n/2}}$.
  • Participants share their experiences with different methods of solving the problem, with one expressing frustration over initially using a more complex approach involving a larger matrix.
Participants generally agree on the mathematical approach to the problem, particularly regarding the implications of even and odd n on the probability. However, there is no consensus on the best method to derive the solution, as different participants express varying levels of complexity in their approaches.
The discussion includes assumptions about the nature of room adjacency and the implications of the ball's movement rules. The calculations depend on the parity of n and the specific arrangement of rooms, which may not be fully detailed in the posts.
jacobi1
The image shows a network of rooms. A ball starts in room P. If the ball moves from one room to another adjacent one every second (assume no time is spent between the rooms) and it randomly chooses a room to go to, find the probability that it reaches room Q after n seconds. A room is adjacent to another room if and only if they share a side-for example, P is adjacent to three rooms.
To clarify, do you want the probability that the ball reaches Q for the first time after n seconds, or do you include the possibility that it may also have visited Q previously?
I include the probability that it may have visited Q previously.
[sp]
First, notice that each move of the ball takes it either from a shaded room to an unshaded room, or from an unshaded room to a shaded room. Since rooms P and Q are both unshaded, it is impossible for the ball to go from P to Q in an odd number of moves. So if $n$ is odd, the probability is $0$.
So assume that $n$ is even, and think about the transition probabilities after two moves. The only way to get from P to Q in two moves is to go via the shaded room between them. The probability of going to this shaded room from P is $1/3$, and the probability of then going from the shaded room to Q is $1/2$. So the probability of going from P to Q in two moves is $1/6$. By symmetry, the probability of going from P to R in two moves is also $1/6$. The probability of going from P back to P in two moves is therefore $2/3$ (since the probabilities must add up to $1$). Thus the matrix $T$ giving the transition probabilities between P, Q and R (in two moves) is $$T = \frac16\begin{bmatrix} 4&1&1 \\ 1&4&1 \\ 1&1&4 \end{bmatrix}.$$ Let $I$ denote the $3\times3$ identity matrix, and let $E$ be the idempotent matrix $$E = \frac13\begin{bmatrix} 1&1&1 \\ 1&1&1 \\ 1&1&1 \end{bmatrix}.$$ Then $T = \frac16(3I+3E) = \frac12(I+E)$, and $$T^k = \frac1{2^k}(I+E)^k = \frac1{2^k}\Bigl(I + {k\choose1}E + {k\choose2}E + \ldots + {k\choose k}E \Bigr) = \frac1{2^k}\bigl((2^k-1)E + I\bigr)$$ (using the fact that $E$ is idempotent). The $(2,1)$-element of this matrix is $\dfrac{2^k-1}{3\cdot 2^k}$. Therefore the probability of the ball being in room Q after an even number $n\;(=2k)$ of moves is $\dfrac{2^{n/2}-1}{3\cdot 2^{n/2}}$.[/sp]
Congratulations, Opalg, your answer is correct. And much faster than mine, too.:)
I did this the hard way. As in, the long, stupid way.
I turned the network of rooms into a graph as in the image by considering the rooms as vertices and numbering them 1 through 9. Room P is vertex number 2 and Q is number 4. Then I made a Markov transition matrix representing the probabilities of going from one room to another.
M=
\left[ {\begin{array}{ccccccccc}
0 & 1 & 0 & 0 & 0 & 0 & 0 & 0 & 0 \\
\frac{1}{3} & 0 & \frac{1}{3} & 0 & 0 & 0 & 0 & 0 & \frac{1}{3} \\
0 & \frac{1}{2} & 0 & \frac{1}{2} & 0 & 0 & 0 & 0 & 0 \\
0 & 0 & \frac{1}{3} & 0 & \frac{1}{3} & \frac{1}{3} & 0 & 0 & 0 \\
0 & 0 & 0 & 1 & 0 & 0 & 0 & 0 & 0 \\
0 & 0 & 0 & \frac{1}{2} & 0 & 0 & \frac{1}{2} & 0 & 0 \\
0 & 0 & 0 & 0 & 0 & \frac{1}{3} & 0 & \frac{1}{3} & \frac{1}{3} \\
0 & 0 & 0 & 0 & 0 & 0 & 1 & 0 & 0 \\
0 & \frac{1}{2} & 0 & 0 & 0 & 0 & \frac{1}{2} & 0 & 0 \\
\end{array} } \right]
(Crying)
Then I diagonalized it (with my handy link, because I refused to do it by hand), took it to the nth power, and I got
M^n = PD^n P^{-1} =
1 & 0 & 1 & 0 & 1 & 1 & 1 & 0 & 0 \\
-\frac{1}{\sqrt 2} & 0 & \frac{1}{\sqrt 2} & 0 & -1 & 1 & 0 & 0 & 0 \\
0 & 1 & 0 & 1 & 1 & 1 & 0 & 1 & 0 \\
\frac{1}{\sqrt 2} & -\sqrt 2 & -\frac{1}{\sqrt 2} & \sqrt{2} & -1 & 1 & 0 & 0 & 0 \\
-1 & 2 & -1 & 2 & 1 & 1 & 0 & 0 & 1 \\
-\frac{1}{2} & 0 & -\frac{1}{2} & 0 & 1 & 1 & 0 & -1 & -1 \\
0 & -2 & 0 & -2 & 1 & 1 & 1 & 2 & 1 \\
0 & \sqrt 2 & 0 & -\sqrt 2 & -1 & 1 & 0 & 0 & 0 \\
\frac{1}{2} & -1 & \frac{1}{2} & -1 & 1 & 1 & -1 & -1 & 0 \\
\end{array} } \right] \times
\left (-\frac{1}{\sqrt 2}\right )^n & 0 & 0 & 0 & 0 & 0 & 0 & 0 & 0 \\
0 & \left (-\frac{1}{\sqrt 2} \right )^n & 0 & 0 & 0 & 0 & 0 & 0 & 0 \\
0 & 0 & \left (\frac{1}{\sqrt 2} \right )^n & 0 & 0 & 0 & 0 & 0 & 0 \\
0 & 0 & 0 & \left (\frac{1}{\sqrt 2} \right )^n & 0 & 0 & 0 & 0 & 0 \\
0 & 0 & 0 & 0 & (-1)^n & 0 & 0 & 0 & 0 \\
0 & 0 & 0 & 0 & 0 & 1 & 0 & 0 & 0 \\
0 & 0 & 0 & 0 & 0 & 0 & 0 & 0 & 0 \\
\frac{2}{9} & -\frac{\sqrt 2}{3} & \frac{1}{9} & \frac{\sqrt 2}{6} & -\frac{1}{9} & -\frac{2}{9} & -\frac{1}{9} & \frac{\sqrt 2}{6} & \frac{1}{9} \\
\frac{1}{18} & -\frac{\sqrt 2}{12} & \frac{1}{9} & -\frac{\sqrt 2}{12} & \frac{1}{18} & -\frac{1}{18} & -\frac{1}{9} & \frac{\sqrt 2}{6} & -\frac{1}{18} \\
\frac{2}{9} & \frac{\sqrt 2}{3} & \frac{1}{9} & -\frac{\sqrt 2}{6} & -\frac{1}{9} & -\frac{2}{9} & -\frac{1}{9} & -\frac{\sqrt 2}{6} & \frac{1}{9} \\
\frac{1}{18} & \frac{\sqrt 2}{12} & \frac{1}{9} & \frac{\sqrt 2}{12} & \frac{1}{18} & -\frac{1}{18} & -\frac{1}{9} & -\frac{\sqrt 2}{6} & -\frac{1}{18} \\
\frac{1}{18} & -\frac{1}{6} & \frac{1}{9} & -\frac{1}{6} & -\frac{1}{18} & \frac{1}{9} & \frac{1}{18} & -\frac{1}{6} & \frac{1}{9} \\
\frac{1}{18} & \frac{1}{6} & \frac{1}{9} & \frac{1}{6} & \frac{1}{18} & \frac{1}{9} & \frac{1}{18} & \frac{1}{6} & \frac{1}{9} \\
\frac{4}{9} & 0 & -\frac{4}{9} & 0 & \frac{1}{9} & \frac{2}{9} & \frac{1}{9} & 0 & -\frac{4}{9} \\
-\frac{2}{9} & 0 & \frac{5}{9} & 0 & -\frac{2}{9} & -\frac{1}{9} & \frac{1}{9} & 0 & -\frac{1}{9} \\
\frac{1}{9} & 0 & -\frac{4}{9} & 0 & \frac{4}{9} & -\frac{4}{9} & \frac{1}{9} & 0 & \frac{2}{9} \\
We only want the $ (2,1) $ entry of the resulting matrix, so we only need the diagonal matrix and the second row and fourth column of the $P$ and $ P^{-1} $ matrices, respectively, to find the final matrix (See? I'm stupid-I figured this out only after I multiplied every single entry of the matrices-but I won't show that here). Multiplying, we get
$$ P_{2 \to 4} = \frac{\left ( 1-2^{-n/2} \right ) \Bigl ( (-1)^{n} +1 \Bigr )}{6}, $$
which works for any n, even or odd (it is 0 for odd n, as is clearly seen).
Confession: I also started by writing down a $9\times9$ matrix. But then I thought: that looks impossibly hard, there must be an easier way. (Headbang) (Emo)
  • · Replies 29 ·
  • · Replies 36 ·
  • · Replies 18 ·
