Uniform distribution with n<1 gives P(X=x)=1/n>1
  • Context: Undergrad
  • Thread starter Thread starter Trollfaz
    Paradox Probability
5 replies · 3K views
Trollfaz
I have a random variable X in range(0,n) where n<1, with a uniform distribution
Then the probability of sample space S=n x P(X=x) x<=n which must be 1
Manipulating the equation P(X=x)=1/n >1
Then this violates the fundamental law of probability which says that any probability must be at most 1.
How do we resolve this paradox here
Are you assuming that the maximum value a probability density function may take is ##1##?
That's certainly not the case.
You are confusing a probability density with a probability. The function you are describing is the probability density function and it can be arbitrarily large. The integral of a probability density is a probability. So only its integral must be no greater than 1, which is the case.
Just to say it explicitly, P(X=x) is always zero. ##P(|X-x|<\epsilon)\approx 2\epsilon f(x)## is the right interpretation of the density function
If you had a uniform rod of mass 1 kg and length 1/2 meter, the density of the rod would be 2 kg per meter, even though the rod only has mass 1 kg. As the others pointed out, probability density is not the the same concept as probability.
An off-topic discussion has been deleted, and since the OP's question has been answered, this thread is now closed. Thanks folks.
