Probability that calls exceed capacity in Poisson distribution with λ=2
3 replies · 4K views
gfields
I need help with aPoisson distribution problem please. Question is: company capable of handling 5 calls every 10 min on new system. Prior to new system, company analysts determined incoming calls to the system are Poisson distributed w/ a mean equal to 2 every 10 min. what is the probability that in a 10 min period more calls will arrive than the system can handle?
Hi gfields! :smile:
What have you tried?
Obviously, we're going to work with a random variable X such that X is Poisson([itex]\lambda[/itex]) distributed. What do you think [itex]\lambda[/itex] is in this case?
I am taking this class online...no instructor...no interaction. I need some guidance on how to think this through. The book is helpful but still lacks clarity.
I understand that the mean before the old system was 2 calls for 10 minutes.
I need to define the segment unit to do the problem... 10 minutes??
The mean is already defined for me. 2
Defining the segment size would be next. I need some discussion here to understand exactly what to use.The event of interest would be P>5 correct?
Once this information is calculated...the Poisson table can be used to find the probability and a comment on the adequacy of the new system can be made.
Good!
Also good.
Indeed, you'll need to calculate [itex]P\{X>5\}[/itex]. You can use tables to calculate this, but you can also do it by hand easily:
[itex]P\{X>5\}=1-P\{X\leq 5\}=1-e^{-2}(1+2+\frac{2^2}{2!}+\frac{2^3}{3!}+\frac{2^4}{4!}+\frac{2^5}{5!})[/itex]
