Probability that Player A beats Player B given different win rates
  • Level: Undergrad
  • Thread starter Thread starter musicgold
    Probabilities Tennis
15 replies · 4K views
musicgold
Hi,
There are two tennis players. Player A wins a point 50% of the time (against any rival), while Player B wins a point 60% of the time against any rival. That is P(A) = 0.50 and P(B) = 0.60.
If Player A plays with Player B, what is the probability that Player A beats Player B, i.e. P(A, B) and the probability that Player B beats Player A, P(B, A) ?
I am not sure how I should simulate this problem.
Thanks,
MG.
Intuitively, since A is an "average" player and B beats the "average" player 60% of the time, perhaps B should win 60% of the time against A.
But it doesn't necessarily work like that. For example, perhaps A and B are equally skilled when playing against people at a given experience level, except that B is better at taking advantage of the weaknesses of poor players than A is. That would give B a higher win percentage, without giving him any advantage against A.
Conclusion: you just don't have enough information.
Player B has a P(A)*P(B) / (P(A)*P(B) + (1-P(A))*(1-P(B))) = 60% chance of winning a point against player A.
The probability of then winning a MATCH against A will then be significantly higher (close to 100%) depending on if they play best of three or five sets.
Justify your claim. What assumptions are you making?
Can you please explain your answer.
I am reading a book: Calculated Bets by Steven Skiena. The book explains mathematical modeling to beat the JAI ALAI betting system.
The author used the following function get the answer to the above problem.
[tex]P (A , B ) = \frac { 1 + [ P (A) - P(B) ]^ \alpha} {2}[/tex] if P(A) >= P(B)
[tex]P (A , B ) = \frac { 1 - [ P (B) - P(A) ]^ \alpha} {2}[/tex] if P(A) <= P(B)
The constant [tex]\alpha >= 0[/tex] is used as a fudge factor to tune the results of this function to the observed stats.
I was using a Bayesian approach.
Let's denote the probability that player [tex]X_1[/tex] wins against player [tex]X_2[/tex] :
[tex]P(W | X_1, X_2)[/tex]
We know the following:
[tex]P(W | A) = \sum\limits_{X}P(W | A, X)P(X) = 0.5[/tex] (called P(A) in posts above)
[tex]P(W | B) = \sum\limits_{X}P(W | B, X)P(X) = 0.6[/tex] (called P(B) in posts above)
Furthermore, chance of anyone beating anyone is 50%
[tex]P(W) = \sum\limits_{X_1}\sum\limits_{X_2}P(W, X_1, X_2)= 0.5[/tex]
due to symmetry.We want to calculate [tex]P(W | A, B)[/tex]. This can be done from assuming that
[tex]P(W, X_1, X_2) = P(X_1 | W)P(X_2 | W)P(W)[/tex].
Then,
[tex]P(W| A, B) = \frac{P(W, A, B)}{P(A, B)}[/tex]
[tex]= \frac{P(A | W)P(B | W)P(W)}{P(A, B)}[/tex]
[tex]= \frac{P(W|A)P(A) P(W|B)P(B) /P(W)}{(P(W|A)P(A) P(W|B)P(B) /P(W)) + P(L|A)P(A) P(L|B)P(B) /P(L)}[/tex]
[tex]= \frac{P(W|A) P(W|B) } {(P(W|A) P(W|B)) + P(L|A)P(L|B) }[/tex]
[tex]= \frac{0.5 * 0.6 } {0.5 * 0.6 + 0.5 * 0.4 }[/tex]
[tex]= 0.6[/tex]
where [tex]P(L|A)=1-P(W|A)[/tex] and [tex]P(L|B)=1-P(W|B)[/tex] is the probability of losing.
It all got a bit technical, sorry about that, but I can't find any more simple derivation...
winterfors,
Thanks for the detail explanation. However, I am stuck at the following equation.
I would appreciate it if you could explain this to me.
winterfors said:
[tex]P(W | A) = \sum\limits_{X}P(W | A, X) = 0.5[/tex] (called P(A) in posts above)
I don't understand how we can sum individual probabilities to get a collective probability of A winning against anybody, as the sum may be bigger than 1.
Let us say, there are 4 players, A, B, X1 and X2, and P(W | A, X1) = 0.4, P(W | A, X2) = 0.7.
Then P(W | A, X1) + P(W | A, X2) > 1
IMHO, we should take an average (or weighted average) of individual winning probabilities to get a collective probability.
You're perfectly right it dosn't make sense. I meant the expectation over [tex]X[/tex] rather than the sum.
(I have corrected my original post)
winterfors,
Thanks. I am still digesting your explanation. I am a bit confused with your notations. Could you explain what the following notations stand for?
[tex]P(X)[/tex]
[tex]P(W, X_1, X_2)[/tex] versus [tex]P(W | X_1, X_2)[/tex]
[tex]P(X_1 | W)[/tex]
[tex]P(W)[/tex]
[tex]P(X)[/tex] Probability that any random player will have the value [itex]X[/itex]. If for instance [itex]X[/itex] is a number describing player's strength, there might be 10% of players with [itex]X=1[/itex], 40% with [itex]X=2[/itex] and 50% with [itex]X=3[/itex].
Note that this probability is not actually used to calculate [itex]P(W | A, B)[/itex], all terms [itex]P(X)[/itex] cancel out along the way.
[tex]P(W | X_1, X_2)[/tex] Probability of player [itex]X_1[/itex] winning over player [itex]X_2[/itex] (vertical bar indicated conditional probability of W (=winning), given players [itex]X_1[/itex] and [itex]X_2[/itex].
[tex]P(W, X_1, X_2)[/tex] Probability of player [itex]X_1[/itex] winning over player [itex]X_2[/itex] times relative abundances of players with [itex]X=X_1[/itex] and [itex]X=X_2[/itex], respectively.
[tex]P(W)[/tex] Probability that any random player will win over another random player
[tex]P(X_1 | W)[/tex] The probability of a random player [itex]X[/itex] will have the value [itex]X = X_1[/itex], given that he has just won a match.
winterfors,
Thanks for bearing with me. I get all the notations except [tex]P(W, X_1, X_2)[/tex].
Could you please explain that concept with an example?
due to symmetry.
Then,
[tex]= 0.6[/tex]
You have a notational problem. The events separated by commas after the conditional bar should commute, but in your notation P(W|A,B) is apparently not the same as P(W|B,A). You need to keep track of which player the W refers to. For example, you might say P(W(A) | A, B), where W(A) means "A wins," A means "A plays," and B means "B plays." It looks like the fact that you don't do this leads to some confusion later on.
As mXSCNT points out, I have messed up the notation in my previous post (definitions of [itex]P(W |X_1)[/itex] and [itex]P(W |X_2)[/itex] are ambiguous). I have tried to make a more formal derivation below.
PRELIMINARIES AND NOTATION
Let's denote the probability that player [itex]A[/itex] wins against player [itex]B[/itex] :
(1) [tex]P(W | A_1, B_2)[/tex]
where the indices 1 and 2 are only to mark that it is player 1 winning over player 2 (and not the other way around)
This implies that [itex]P(W | A_1, B_2)[/itex] is equal to the probability that player [itex]B[/itex] loses to player [itex]A[/itex]
(2) [tex]P(W | A_1, B_2) = P(L | B_1, A_2)[/tex]
One can define joint probability distributions over the space of all (pairwise) combinations of players and all outcomes (Win / Loss) by multiplying with [itex]P(A)P(B)[/itex]
(3) [tex]P(W, A_1, B_2) = P(W | A_1, B_2) P(A) P(B)[/tex]
One can also define marginal probability distributions by summing over all [itex]X_1[/itex] or [itex]X_2[/itex]
(4) [tex]P(W , A_1) = \sum\limits_{X_2}P(W, A_1, X_2)[/tex]
(5) [tex]P(W , B_2) = \sum\limits_{X_1}P(W, X_1, B_2)[/tex]
(6) [tex]P(W) = \sum\limits_{X_1}\sum\limits_{Y_2}P(W, X_1, Y_2)[/tex]
From equation (2) we can deduce also that [itex]P(W, A_1) =P(L, A_2)[/itex] and [itex]P(W , B_1) =P(L , B_2)[/itex].
Finally, we can define the conditional probabilites:
(7) [tex]P(W | A_1) P(A) = P(A_1|W) P(W) = P(W, A_1)[/tex]
(8) [tex]P(W | B_2) P(B) = P(B_2|W) P(W) = P(W, B_2)[/tex]
WHAT WE KNOW
(9) [tex]P(W | B_1) = 0.6[/tex]
(10) [tex]P(W | A_2) = 0.5[/tex]
ASSUMTIONS MADE
(11) [tex]P(W) = P(L)= 0.5[/tex]
The probability of a random player winning (or losing) against another random player is exactly 50%
(12) [tex]P(W, B_1, A_2) = P(B_1 | W) P(A_2 | W) P(W)[/tex]
This assumption can be justified by the maximum entropy principle, since it minimizes the Shannon information of [itex]P(O, B_1, A_2)[/itex] (O= W or L) given that we know [itex]P(B_1 | W)[/itex], [itex]P(A_2 | W)[/itex] and [itex]P(W)[/itex].
DEDUCTIONS FROM ABOVE
[tex]P(W| B_1, A_2) = \frac{P(W, B_1, A_2)}{P(B) P(A)}[/tex]
Inserting (12) gives
[tex]P(W| B_1, A_2) = \frac{P(B_1 | W) P(A_2 | W) P(W)}{P(B) P(A)}[/tex]
Using (7) and (8) we can finally write
[tex]P(W| B_1, A_2) = \frac{P(W| B_1) P(W| A_2 ) }{P(W)}[/tex]
Inserting (9) (10) and (11) gives
[tex]P(W| B_1, A_2) = \frac{0.6 * 0.5 }{0.5} = 0.6[/tex]
That is, the probability of player B beating player A is 60%
winterfors,
Thanks a lot. Though your solution is not fully clear to me, I appreciate your efforts.
I think I need to do more reading on the Bayesian probability theory.
MG.
musicgold said:
Hi,
Then, considering long time of observation (or "after a large amount of points played" ), for each 10 points played, Player A wins 5 points, and Player B wins 6 points...
If Player A plays with Player B,...
Kittel Knight said:
Then, ...for each 10 points played, Player A wins 5 points, and Player B wins 6 points...
It seems the OP, the way it is, leads to a strange conclusion!
Who is wrong: me, or the assumptions in the OP?
:confused:
