Probably easier than I think f(xn)=nf(x)?
  • Thread starter Thread starter geoman
The discussion centers on proving that for each positive integer n and each real number x, the equation f(nx) = nf(x) holds true, given that f(x) is an additive function defined by f(x+y) = f(x) + f(y). Participants suggest using mathematical induction as a method for proof. Key points include the necessity of correctly applying the definition of an additive function and clarifying the notation used for the function's iterations. The consensus is that while the induction approach is valid, the initial assumptions and definitions must be clearly established to avoid confusion.
  • Additive functions and their properties
  • Mathematical induction techniques
  • Basic algebraic manipulation
  • Understanding of function notation and definitions
  • Study the principles of mathematical induction in depth
  • Explore examples of additive functions and their applications
  • Review algebraic proofs involving function properties
  • Learn about common pitfalls in mathematical notation and definitions
Students studying mathematics, particularly those focusing on functional equations, educators teaching mathematical induction, and anyone interested in the properties of additive functions.
geoman
1. show that for each positive integer n and each real number x, f(nx)=nf(x).
f(x) is an additive function (f(x+y)=f(x)+f(x))
Well I'm thinking that I can just use mathematical induction to show that:
1) f((1)x)=1f(x)
2)f(nx)=nf(x)=f_{}1(x)+f_{}2(x)+...+f_{}n(x) (assume this is true)
3)f((n+1)x)=(n+1)f(x)=f_{}1(x)+f_{}2(x)+...+f_{}n+1(x)
from here it would just be algebra. is this right?
note: the numbered functions above are supposed to be subscripted but i messed it up somehow. They are only supposed to number the functions as I add the function n times and then n+1 times
How you have presented this problem is confusing.
The statement you presented in section 1 is not true in general.
The statement you presented as a relevant equation is more than just relevant; it is part of the problem statement, I'm pretty sure. Also, you have a typo, and this equation should be f(x + y) = f(x) + f(y).
In your attempt at a solution, yes you should assume that f(nx) = nf(x), but how in the world do you go from nf(x) to a sum of powers of f(x)?
Look at what happens with f(x + x). What is that equal to by your original assumptions? You have a way to go before you will be able to tackle the induction step, IMO, so let's get up to speed with some simple calculations first.
Yes, induction is the way to go.
1) f((1)x)=1f(x)
What? Where in the world did that horribly complicated right end come from? You haven't even defined "f1", "f2", etc.
Just use f(nx)= nf(x).
You can't use "f((n+1)x)= (n+1)f(x)", that's what you want to prove. You can use the fact that f((n+1)x)= f(nx+x)= what?
  • · Replies 20 ·
