Problem 42 on Gelfand's Algebra (on neighbor fractions)
  • Thread starter Thread starter vsgarciaaleman
    Algebra Fractions
The problem involves neighbor fractions defined by the condition that their difference has a numerator of ±1. Participants are tasked with proving certain properties related to these fractions, including simplification, the relationship between sums of fractions, and constraints on other fractions that may lie between them.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the implications of common factors in fractions and explore the validity of the proposed relationships between neighbor fractions. Some express confusion over the correct formulation of the sum of fractions and question the reasoning behind certain steps in the proofs.
There is an ongoing exploration of the properties of neighbor fractions, with some participants providing hints and alternative approaches. Confusion remains regarding specific steps in the reasoning, and participants are encouraged to clarify their understanding of matrix concepts and determinants as they relate to the problem.
Participants note the challenge of applying matrix concepts without prior knowledge of the subject, and there are indications of differing interpretations of the problem's requirements. Some participants express uncertainty about the implications of certain inequalities and the existence of fractions within specified bounds.
vsgarciaaleman
Fractions ##\frac{a}{b}## and ##\frac{c}{d}## are called neighbor fractions if their difference ##\frac{ad - bc}{bd}## has numerator ##\pm 1##, that is, ##ad - bc = \pm 1##.
Prove that
(a) in this case neither fraction can be simplified (that is, neither has any common factors in numerator and denominator);
(b) if ##\frac{a}{b}## and ##\frac{c}{d}## are neighbor fractions, then ##\frac{a + b}{c + d}## is between them and is a neighbor fraction for both ##\frac{a}{b}## and ##\frac{c}{d}##; moreover,
(c) no fraction ##\frac{e}{f}## with positive integer ##e## and ##f## such that ##f < b + d## is between ##\frac{a}{b}## and ##\frac{c}{d}##
We saw in page 23 that “it is a horrible error (which, of course, you avoid) to add numerators and denominators separately:
$$\frac{2}{3} + \frac{5}{7} \rightarrow \frac{2 + 5}{3 + 7} = \frac{7}{10}$$
Instead of the sum this operation gives you something in between the two fractions you started with (##7/10 = 0.7## is between ##2/3 = 0.666##... and ##5/7 = 0.714285##...).
The first part is proved as follows:We prove that if a fraction has common factors in numerator and denominator, we cannot get a possible solution:##\frac{xi}{xj} - \frac{c}{d} = \frac{\pm 1}{xjd}##
##\frac{xid - xjc}{xjd} = \frac{\pm 1}{xjd}##
##\frac{x\times(id - jc)}{xjd} = \frac{\pm 1}{xjd}##
##\frac{id - jc}{jd} = \frac{\pm 1}{xjd}##
##\frac{id - jc}{jd}\times jd = \frac{\pm 1}{xjd}\times jd##
##id - jc \neq \frac{\pm 1}{x}##
Except in the case that ##x = \pm 1##I think it's ok that way. But now in the following part of the problem I think that it has a mistake, and where he says '##\frac{a + b}{c + d}## is between them and...' it should say '##\frac{a + c}{b + d}## is between them and...'due to what we saw in page 23. If that were the case, then the solution should be:
##\frac{a}{b} - \frac{a + c}{b + d} = \frac{\pm 1}{b (b + d)}##
##\frac{a (b + d) - b (a + c)}{b (b + d)} = \frac{\pm 1}{b (b + d)}##
##\frac{ab + ad - ba - bc}{b (b + d)} = \frac{\pm 1}{b (b + d)}##
##\frac{ad - bc}{b (b + d)} = \frac{\pm 1}{b (b + d)}##
##\frac{ad - bc}{b^{2} + bd} \times b^{2} = \frac{\pm 1}{b^{2} + bd} \times b^{2}##
##\frac{ad - bc}{bd} = \frac{\pm 1}{bd}##
And that's what we had as a neighbor fraction. The last question is driving me crazy. I can't see how to solve that, and would appreciate a hint or something.
Thanks for your attention and excuse me for my bad English!
Let me give you some common tools at hand so that you can learn something more out of it than just getting a solution.
If you arrange your fractions as a matrix [tex]A = \begin{bmatrix}a & b\\ c & d\end{bmatrix}[/tex] then you can define
[tex]A \cdot \bar{A} = \begin{bmatrix}a & b\\ c & d\end{bmatrix} \cdot \begin{bmatrix}\bar{a} & \bar{b}\\ \bar{c} & \bar{d}\end{bmatrix} = \begin{bmatrix}a \cdot \bar{a} + b \cdot \bar{c} & a \cdot \bar{b} + b \cdot \bar{d} \\ c \cdot \bar{a} + d \cdot \bar{c} & c \cdot \bar{b} + d \cdot \bar{d} \end{bmatrix}[/tex] which is called matrix multiplication.
Further the term ##det(A) = a \cdot d - b \cdot c## is called determinate of ##A##. You can show that ##det(A \cdot \bar{A}) = det(A) \cdot det(\bar{A})##.
Applying this to your problems (a) and the last part of (b) the solutions can be stated in a more elegant way, although it does just that what you did. For the second part of (b) consider multiplying ##A## with \begin{bmatrix}1 & 1\\ 0 & 1\end{bmatrix} and \begin{bmatrix} 1& 0\\ 1 & 1\end{bmatrix}.
And you are right: ##\frac{a+b}{c+d}## is not in between ##\frac{a}{b}## and ##\frac{c}{d}## as [tex]\begin{bmatrix}1 & 3\\ 2 & 7\end{bmatrix}[/tex] shows.
Hint on (c): Let us assume all integers are positiv, ##a d - b c = 1## and ##0 ≤ \frac {c}{d} ≤ \frac {e}{f} ≤ \frac {a}{b}##
Then ##bcf ≤ edb ≤ adf = (1 + bc) f = f + bcf < bcf## which is a contradiction, i.e ##\frac{e}{f}## cannot exist.
fresh_42 said:
the term det(A)=a⋅d−b⋅c is called determinate of A.
Determinant.
haruspex said:
Determinant.
thx, was in a hurry :wink:
Thank you very much for your answers! Since I haven't studied matrices yet I can't apply what you told me @fresh_42 but I've put a mark on the problem to be back when I begin with matrices!
I didn't follow the last step, where you write "< bcf". Where does that come from? You don't seem to have used f<b+d, so maybe it's from that somehow.
You are right. I made a fat mistake. Embarrassing :sorry: I have to restart it.
