Problem about a group with two inner direct product representations
The discussion revolves around a problem in group theory concerning an Abelian group G that has two representations as internal direct products of subgroups, specifically G = H x K1 and G = H x K2. Participants explore the implications of the assumption that K1 is a subset of K2 and seek to demonstrate that K1 equals K2.
  • One participant presents a proof attempt involving the identity element of H and an arbitrary element of K2, concluding that K2 is a subset of K1.
  • Another participant agrees with the proof but suggests it could be simplified, emphasizing that it suffices to show K2 is a subset of K1 given K1 is a subset of K2.
  • Concerns are raised regarding whether the proof adequately utilizes the properties of subgroups or the fact that G is Abelian.
  • Another participant argues that the uniqueness of the internal direct product representation follows from the equality of Cartesian products, asserting that the assumption K1 is a subset of K2 is redundant.
Participants express differing views on the necessity of certain assumptions in the proof and whether the proof correctly follows from the properties of the groups involved. There is no consensus on the sufficiency of the proof or the implications of the assumptions.
Some participants note that the assumptions regarding the existence of internal direct product representations may not be sufficient to establish uniqueness, pointing to the need for clarity on the properties of subgroups and the structure of G.
stragequark
The problem: Suppose G is Abelian with two representations as the internal direct product of subgroups: G=HxK1, G=HxK2. Assume K1 is a subset of K2 and show K1=K2.
My attempted solution: I took the element (e_H, k_2), where e_H is the identity element of H and k_2 is an arbitrary element in K2, and multiplied it by an arbitrary element of HxK1 which I called (h,k_1) and I said the product (h, k_1*k_2) is an element of G=HxK1 and hence k_1*k_2 is an element of K1. Since K1 is closed under inverses I know that k_2 is an element of K1 since I can multiply k_1*k_2 by k_1 inverse. so K2 is a subset of K1.
Alternatively I thought that the order of G would be ord(H)ord(K1) and also ord(H)ord(K2), so ord(K1)=ord(K2). I am not given that these are finite, but may it still follow that if ord(K1)=ord(K2) and K1 is a subset of K2 that K1=K2?
I am suspicious of my proof because it doesn't use some of the problem's assumptions.
Your help is much appreciated.
Hi stragequark,
Your attempted proof is actually correct (you can just say at the end that since $K_2 \subset K_1$ as well, $K_1 = K_2$), but it may be simplified further. Again, since $K_1 \subset K_2$ it suffices to show $K_2 \subset K_1$. To this end, take an arbitrary $k_2\in K_1$. Then $(e_H, k_2) \in H \times K_2 = H \times K_1$, which implies $k_2 \in K_1$. Therefore $K_2 \subset K_1$.
Euge said:
Hi stragequark,
Are you sure? This proof doesn't use any properties of subgroups or G being Abelian, which is why I'm worried.
I'm not too sure that the implication in
is true.
is true.
Most of the assumptions you're worried about concern the existence, not uniqueness, of an internal direct product representation for $G$. The uniqueness property follows from equality of cartesian products (of nonempty sets): $A \times B = C \times D$ if and only if $A = C$ and $B = D$. So in fact, the hypothesis $K_1 \subset K_2$ is redundant. For given $G = H \times K_1$ and $G = H\times K_2$, we have $H \times K_1 = H \times K_2$. Since $H$, $K_1$ and $K_2$ are nonempty (being subgroups of $G$), $K_1 = K_2$ by equality of cartesian products.
  • · Replies 16 ·
