Problem about units conversion: cm^2 --> m^2
inuka00123
I need to find how much meters equal to area of 100cm²
100cm = 1m
10cm = 1/10m = 0.1m
10cm² ≠ (1/10m)² = (0.1m)²
in the problem 100 cm is obviously equal to 1m, and 10cm is equal to 1/10m and it is equal to 0.1m, but when you take the square of the 10cm it is obviously does not equal (1/10m)² nor (0.1m)², therefore (10cm x 10cm ≠ 1/10m x 1/10m = 0.1m x 0.1m), then to what 10cm x 10cm is equal to in meters? 1/100m or 0.01 meters does not equal to 100cm, this problem seems really easy, but I've tried come up with solution but I wasn't able to. if I take off the units it is obvious that one doesn't not equal to other, any help would be really appreciated.
If ##x=y ## then ##x^2=y^2##.
If ##10cm=(1/10)m## then what is ##(10cm)^2##?
No, it is 0.01 m² = 100 cm². The exponent on the units is important:
  • (0.1 m) X (0.1 m) = (0.1 X 0.1) (m X m) = 0.01 m.m = 0.01 m²;
  • (10 cm) X (10 cm) = (10 X 10) (cm X cm) = 100 cm.cm = 100 cm².
You can even have uncommon units like (0.1 m) X (10 cm) = (0.1 X 10) (m X cm) = 1 m.cm which is also equal to 0.01 m² or 100 cm².
inuka00123 said:
Homework Statement: I need to find how much meters equal to area of 100cm²
That can't be answered! The meter is a unit of length and the square centimeter is a unit of area. You can't convert an area to a length, it's like converting apples to oranges. The way you've written your thread title indicates that you understand this. You want to convert 100 cm2 to square meters.
Suppose the figure below is a 10 cm by 10 cm square.
It has an area of 100 cm2 because (10 cm)(10 cm) = 100 cm2.
(You can verify this by counting grid squares. There are 100 grid squares, each with an area of 1 cm2.)
The figure is also a 0.1 m by 0.1 m square. What is it's area in square meters?
You can also look at it this way: How many of these 10 cm by 10 cm squares will fit in a square meter? So, this 10 cm by 10 cm square is what fraction of a square meter?
Likes jack action
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
