Problem during finding <x> in p space
  • Level: Undergrad
  • Thread starter Thread starter Shell_E
    Space
4 replies · 1K views · last reply
Shell_E
Thank you advance for help!
So the problem is find <x> in P space.
The solution's logic is use formula:
The submit with
Then one will get the integral
by noticing that
, one can replace xeipx/ħ in the integral
so that
and then after solving the integral one can find the expectation value for x.
The part I don't understand is why
, firstly I am not sure where is the minus sign comes from. Next I don't think I can just change the order of eipx/ħ and Φ because the term d/dp.
Could anyone help me figure the integral out?
Thank you everybody.
Shell
I think that integration by parts comes into this one.
It comes about because momentum is a Hermitian operator: http://www.colby.edu/chemistry/PChem/notes/MomentumHermitian.pdf
@Jilang @DrClaude Thank you for help! I mislead by the integral sign to think it gained by doing some rearrangement inside the integral. Everything become clear if I do integral by part and use the fact that momentum operator is hermitian. Thanks a lot!
The tacit assumption is that any wave function decreases at infinity slower than any polynomial, thus can be safely assumed to be a Schwartz test function. The Schwartz space is invariant under the Fourier transform and provides a domain of essential self-adjointness for the momentum operator over the entire real line.
Because of this explanation, you can use partial integration in the improper definite integral and discard the so-called "surface term" (a misnomer, because we're in 1D).
