Problem in magnetic effects of current
4 replies · 3K views · last reply
logearav
a long straight wire carries a current of 2A. an electron travels with a speed of 4*10^4 m/s parallel to the wire at a distance of 0.1 metre from it. what force does the magnetic field exert on the moving electron
what formula should i use? is it f= BqV SIN[tex]\theta[/tex] or f= BIl sin[tex]\theta[/tex]
or f=4*3.14*10^-7* I1*I2* L)/(2*3.14*a)
he attempt at a solution[/b]
A reasonable question. Here's a hint: does the question ask for the force on a single charge, or the force on a current-carrying wire?
"a long straight wire carries a current of 2A. an electron travels with a speed of 4*10^4 m/s parallel to the wire at a distance of 0.1 metre from it. what force does the magnetic field exert on the moving electron"
the problem is like this. nothing mentioned extra.
To make my point clearer:
That is the force on a charge q moving with speed V.
... or f= BIl sin[tex]\theta[/tex]
This is the force on a wire of length l and current I.
... or f=4*3.14*10^-7* I1*I2* L)/(2*3.14*a)
This one is the force between two wires of length L.
So, to figure out which equation applies here, you need to figure out if you need the force on a single charge, the force acting on a single wire, or the force acting between a pair of wires.
