What is the Average Value of |dφ/dz|^2 over the Open Unit Disk?
  • Context: Undergrad
  • Thread starter Thread starter Euge
The average value of |dφ/dz|^2 over the open unit disk is determined through the holomorphic mapping φ(z) = (z - a)/(1 - ̄az), where a is a fixed complex number in the unit disk ℝD. The integral to compute is given by (1/π)∬ℝD |φ'(x + yi)|^2 dx dy. The solution involves converting the integral into polar coordinates and utilizing the Poisson kernel for simplification. The problem was successfully solved by user Opalg, providing a definitive approach to the calculation.
  • Understanding of holomorphic functions and their properties
  • Familiarity with complex analysis concepts, particularly mappings in the unit disk
  • Knowledge of polar coordinates and their application in double integrals
  • Experience with the Poisson kernel and its role in harmonic functions
  • Study the properties of holomorphic mappings in complex analysis
  • Learn about the application of polar coordinates in evaluating integrals
  • Research the Poisson kernel and its significance in harmonic analysis
  • Explore advanced topics in complex analysis, such as conformal mappings
Mathematicians, students of complex analysis, and anyone interested in advanced calculus and harmonic functions will benefit from this discussion.
Euge
MHB
POTW Director
Here is this week's POTW:
Suppose $a$ is a fixed complex number in the open unit disk $\Bbb D$. Consider the holomorphic mapping $\phi : \Bbb D \to \Bbb D$ given by $\phi(z) := (z - a)/(1 - \bar{a}z)$. Find, with proof, the average value of $\left\lvert\frac{d\phi}{dz}\right\rvert^2$ over $\Bbb D$, i.e., the integral $$\frac{1}{\pi}\iint_{\Bbb D} |\phi'(x + yi)|^2\, dx\, dy$$-----
Remember to read the https://mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to https://mathhelpboards.com/forms.php?do=form&fid=2!
I'm giving another week for members to solve this POTW. As a hint, consider writing the integral in polar coordinates, and note that the integrand can be written as an expression of the Poisson kernel.
This week's problem was solved correctly by Opalg. You can read his solution below.
By the quotient rule, $\phi'(z) = \dfrac{1-\bar{a}z + \bar{a}(z-a)}{(1-\bar{a}z)^2} = \dfrac{1 - \bar{a}a}{(1-\bar{a}z)^2}$, and therefore $$|\phi'(z)|^2 = \phi'(z)\overline{\phi'(z)} = \frac{(1 - \bar{a}a)^2}{(1-\bar{a}z)^2(1-a\bar{z})^2} = \frac{(1 - \bar{a}a)^2}{(1-2\text{re}(\bar{a}z) + \bar{a}a\bar{z}z)^2}.$$ So we want to evaluate $$\frac1\pi \iint_{\Bbb D}\frac{(1 - \bar{a}a)^2}{(1-2\text{re}(\bar{a}z) + \bar{a}a\bar{z}z)^2}\,dA$$, where $A$ denotes area measure. The substitution $z\mapsto e^{i\arg a}z$ leaves the integral unchanged (it just represents a rotation of the disc, which preserves the measure), and has the effect of replacing $a$ by $|a|$. For the rest of the proof I will write $a$ instead of $|a|$, so that $a$ is real, positive, and less than $1$.
Next, write the integral on terms of polar coordinates as $$ \frac{(1 - a^2)^2}\pi \iint_{\Bbb D}\frac{1}{(1-2a\,\text{re}(z) + a^2\bar{z}z)^2}\,dA = \frac{(1 - a^2)^2}\pi \int_0^1\int_0^{2\pi}\frac{1}{(1-2ar\cos\theta + a^2r^2)^2}\,r\,d\theta \,dr.$$ Taking the theta integral first, substitute $w = e^{i\theta}$ to get $$ \begin{aligned}\int_0^{2\pi}\frac{1}{(1-2ar\cos\theta + a^2r^2)^2}\,d\theta &= \oint_{\partial\Bbb D}\frac1{\bigl((1+a^2r^2) - ar(w+w^{-1})\bigr)^2}\frac{dw}{iw} \\ &= \oint_{\partial\Bbb D}\frac{-iw}{(arw^2 - (1+a^2r^2)w + ar)^2}dw \\ &= \oint_{\partial\Bbb D}\frac{-iw}{a^2r^2(w - ar)^2\bigl(w - \frac1{ar}\bigr)^2}dw. \end{aligned} $$ By the Cauchy Integral Formula (and the fact that $ar$ lies inside $\Bbb D$), that last integral is equal to $$ \begin{aligned}\frac{2\pi i}{a^2r^2}\frac d{dw}\biggl(\frac{-iw}{(w - \frac1{ar})^2}\biggr)\bigg|_{w=ar} &= \frac{2\pi}{a^2r^2}\frac{(w - \frac1{ar})^2 - 2ar(w - \frac1{ar})}{(w - \frac1{ar})^4}\bigg|_{w=ar} \\ &= \frac{2\pi}{a^2r^2}\frac{ar - \frac1{ar} - 2ar}{(ar - \frac1{ar})^3} \\ &= \frac{2\pi(1 + a^2r^2)}{(1 - a^2r^2)^3}.\end{aligned}$$ Now plug that into the $r$-integral and then make the substitution $s = a^2r^2$, to get $$ \begin{aligned} \frac1\pi \iint_{\Bbb D}\frac{(1 - \bar{a}a)^2}{(1-2\text{re}(\bar{a}z) + \bar{a}a\bar{z}z)^2}\,dA &= \frac{(1 - a^2)^2}\pi \int_0^1\frac{2\pi r(1+a^2r^2)}{(1 - a^2r^2)^3}dr \\ &= \frac{(1 - a^2)^2}{a^2}\int_0^{a^2}\frac{1+s}{(1-s)^3}ds \\ &= \frac{(1 - a^2)^2}{a^2}\int_0^{a^2}\biggl(\frac2{(1-s)^3} - \frac1{(1-s)^2} \biggr)ds \\ &= \frac{(1 - a^2)^2}{a^2}\biggl[\frac1{(1-s)^2} - \frac1{1-s}\biggr]_0^{a^2} \\ &= \frac{(1 - a^2)^2}{a^2}\frac{a^2}{(1 - a^2)^2} \\ &= \large 1 \quad! \end{aligned}$$
Edit. Euge has pointed out that my solution does not work when $a=0$. To deal with that case, note that the function then becomes $\phi(z) = z$. So $\phi'(z)$ is the constant $1$, and the average value of its square over $\Bbb D$ is also $1$. Thus the result $$\frac{1}{\pi}\iint_{\Bbb D} |\phi'(x + yi)|^2\, dx\, dy = 1$$ still holds in that case.
