Problem related to the vector potential of B
The discussion revolves around the vector potential A in the context of a particle with mass m and charge q moving in a time-independent magnetic field B(r). Participants are exploring the relationship between the vector potential and the magnetic field, particularly focusing on the expression for the time derivative of A as perceived by the particle.
  • Participants discuss the implications of the magnetic field being time-independent and how this affects the vector potential A. There is an exploration of the expression (v.∇)A and its validity, as well as the relationship between A and B given that ∇.B = 0. Questions arise regarding the transformation of ∇ in the context of the problem.
The discussion is active, with participants sharing insights and clarifications. Some have provided additional context, such as referencing the original question paper for better understanding. There is a recognition of the complexity of the topic, and while some participants feel they are nearing a resolution, others express the need for further study of vector calculus identities.
Participants note the importance of the condition ∇.B = 0 and its implications for the vector potential. There is also mention of the need to understand the mathematical identities involved in vector calculus to fully grasp the problem.
nuclear_dog
A particle of mass m and charge q moves in a region with a magnetic field B(r) which is time independent. What is [itex]\frac{dA}{dt}[/itex] as seen by the particle.
Since the B field is not varying with time, I know that the change in A will be due to the change in position of particle with time. It should be (∂A/∂x)vx + (∂A/∂y)vy + (∂A/∂z)vz . So can it be (v.∇)A. But I cannot seem to be able to go furthur.
A is a scalar, so (v.∇)A n= v.(∇A), right? And ∇A =?
I am sorry I forgot to add that in the question it was given that since ∇.B = 0 , therefore we can write B = ∇XA , where A is a vector. So I am not sure that we can use the transformation of ∇ in the expression.
OK, I see. What makes you think (v.∇)A is an inadequate answer?
haruspex , I got hold of the original question paper today and have attached a screenshot of it. Please take a look at it to clearly understand the question , since I might not have explained it properly.
Since (dp/dt) = F = q(vXB) , hence if we can show that ∇X{d/dt( p + qA)} = 0 , it would mean that (d/dt(p + qA)) is a gradient of some function. But I haven't been able to prove that ∇X{d/dt( p + qA)} = 0 , by using dA/dt = (v.∇)A .
##\frac{d\vec{p}}{dt} =q\vec{v}\times\vec{B}##
##\frac{d}{dt}\left(\vec{p}+q \vec{A}\right) = q \vec{v}\times \vec{B}+q \left( \vec{v}.\vec{\nabla} \right) \vec{A} = q \vec{v}\times \left( \vec{\nabla}\times\vec{A}\right)+q \left( \vec{v}.\vec{\nabla} \right) \vec{A} ##
Here I venture into areas I know even less about, based what I read at http://en.wikipedia.org/wiki/Curl_%28mathematics%29:
## \vec{v}\times \left(\vec{\nabla}\times\vec{A}\right) = \vec{\nabla_A}\left(\vec{v}.\vec{A}\right) - \left(\vec{v}.\vec{\nabla}\right)\vec{A}##
So
##\frac{d}{dt}\left(\vec{p}+q \vec{A}\right) = q \vec{\nabla_A}\left(\vec{v}.\vec{A}\right)##
Does that help?
Thanks, that actually solves the problem. Although I will have to read up on the identities of vector calculus to feel satisfied on this question.
