Problem: Rotational Kinematics; Moment of Inertia
The discussion focuses on solving a physics problem involving rotational kinematics and the moment of inertia of a stick with a mass dropped onto it. The moment of inertia for the stick is established as 1/3ML². The speed of the mass just before impact is calculated using the formula v=sqrt(2gH), while the angular speed immediately after impact is determined to be w=3sqrt(2g(H-L))/L. The center of mass for the system is identified at 3/4L, which is crucial for calculating the linear speed of the mass at its lowest point and the mechanical energy lost during the collision.
  • Understanding of rotational kinematics
  • Familiarity with the concept of moment of inertia
  • Knowledge of conservation of momentum and energy principles
  • Ability to apply kinematic equations in physics problems
  • Study the derivation of moment of inertia for various shapes
  • Learn about the conservation of mechanical energy in inelastic collisions
  • Explore the concept of center of mass in composite systems
  • Investigate advanced kinematic equations and their applications in rotational motion
Students studying physics, particularly those focusing on mechanics and rotational dynamics, as well as educators seeking to clarify concepts related to moment of inertia and energy conservation in collisions.
m2010
A mass (M) is dropped from height (H) onto one end of a stick of mass (M) and of length (L) pivoted around the opposite end. Upon collision the mass adheres to the stick. Respond to the following in terms of M, L, H, and g.
a. Find speed of mass just before impact
b. Find angular speed of the system immediately after impact
c. Find linear speed of the mass M at its lowest point (when stick is vertical).
d. Determine the mechanical energy lost as a result of the collision.
The moment of inertia of the stick is 1/3ML^2.
conservation of energy
a. v=sqrt(2gH)
b. w= sqrt(2gH)/2L
I need help with c and d.
a) use kinematic equations
you know that it falls a distance (H - L) so use the (v_final)^2 = (v_initial)^2 + 2*a*d where v_initial is 0 and a is acceleration which equals g (gravity), d distance
(v_final) = sqrt(2*g*(H-L))
b) use the the eq L = I*(omega, which i will use as 'w')
so w = L/I
I = 1/3 * M * L^2
also use L = r x p (r crossproduct p)
in this case, theta is 90 degrees so cos(90deg) = 1
L = L * M * v_final
so w = L*M*sqrt(2*g*(H-L))/(1/3)*M*L^2
w = 3sqrt(2g(H-L))/L
c)for part C, you would need to find the center of mass of the stick. the stick weighs M and the mass weighs M, so the center of mass is 3/4 out toward the end of the stick. therefore, the center of mass falls 3/4 * L
shoot I am not 100% sure how to do the next part ... i had this on a test but now i forgot it -.-
I actually think I had part a right...I attached the diagram given. Can anyone give a more detailed explanation of parts c and d? (L is the length of the stick; M is the mass of the stick)
  • · Replies 28 ·
