I Problem with calculating projections of curl using rotation of contour
  • Thread starter Thread starter Mike_bb
Mike_bb
Hello!
I tried to calculate projections of curl using rotation of coordinate system but I encountered with following problem.
Given:
##rot_xA=\frac{\partial A_z}{\partial y}-\frac{\partial A_y}{\partial z}=0##
##rot_yA=\frac{\partial A_x}{\partial z}-\frac{\partial A_z}{\partial x}=1##
##rot_zA=\frac{\partial A_y}{\partial x}-\frac{\partial A_x}{\partial y}=0##
I rotated ##yz##-plane of this coordinate system by an angle ##45## degrees about ##x##-axis and used rotation matrix to calculate projections on ##x'##,##y'##,##z'## directions:
\begin{bmatrix}
x' \\
y' \\
z' \\
\end{bmatrix}
\begin{bmatrix}
1 & 0 & 0 \\
0 & cos(45) & -sin(45) \\
0 & sin(45) & cos(45) \\
\end{bmatrix}
\begin{bmatrix}
0 \\
1 \\
0 \\
\end{bmatrix}
\begin{bmatrix}
x' \\
y' \\
z' \\
\end{bmatrix}
\begin{bmatrix}
0 \\
\sqrt(2)/2 \\
\sqrt(2)/2 \\
\end{bmatrix}
On the other hand I tried to follow another way:
I rotated ##yz##-plane of this coordinate system and contour ##\Delta L## by an angle 45 degrees about ##x##-axis and applied equality for projections of curl on ##x'##,##y'##,##z'## directions:
##x'=rot_{x'}A=\frac{\partial A_z}{\partial y}-\frac{\partial A_y}{\partial z}=0##
##y'=rot_{y'}A=\frac{\partial A_x}{\partial z}-\frac{\partial A_z}{\partial x}=\sqrt(2)/2##
##z'=rot_{z'}A=\frac{\partial A_y}{\partial x}-\frac{\partial A_x}{\partial y}=0##
Wrong result is obtained at this step because we should obtain also ##z'=\sqrt(2)/2##.
Could anyone explain where did I go wrong?
Thanks!
I'm not sure where you went wrong in your case but if you were computing the curl in xyx coordinates and then switched to spherical coordinates then you need a jacobian factor to adjust computations.
It took me quite a while to overcome the notion that the differential volume element in xyz space was
##dV = dxdydz##
vs the spherical differential volume
##dV = \rho^2 \sin\phi \, d\rho \, d\phi \, d\theta##
I always thought they had the same volume and never appreciated the importance of the Jacobian.
https://en.wikipedia.org/wiki/Jacobian_matrix_and_determinant
In your case, you rotated the surface element but not the basis vectors.
Basically, you’re mixing coordinate systems.
You need to compute dy’ and dz’ using the chain rule, right? Since the dx is essentially the same as dx’ in both coordinate systems through rotational symmetry.
##dV = dxdydz##
No. It's not my problem. I just want to calculate projection of curl on x',y',z' directions using contour rotation in coordinate system.
But read up on it: you have to provide a transformation because y’ is composed of an x and a y component, and you need to take that and differentiate via the chain rule.
Projections of curl can be calculated using this formula:
I substituted values of curl projections (post #1) in this formula and obtained wrong result (for x', y', z'). I don't understand why.
Could anyone know what's wrong?
It's a little hard to say what went wrong because you haven't given any detail of what you actually did.
The first bit I understand. You have a vector field ##\vec{A}## and you computed the components of ##\vec{\nabla}\times\vec{A}## in your ##x,y,z## coordinate system, then applied a rotation matrix to get its components in your ##x',y',z'## system.
The second bit I am not sure what you did. I think you attempted to compute the curl directly in the primed coordinate system. Of course this should work, but I can't guess where it went wrong. I would note that this isn't right (or at least is missing a lot of steps to show that it's right):
All the ##x,y,z## should have primes. Presumably you have a chain of reasoning that will let you write those partial differentials in terms of the partial differentials with respect to the unprimed coordinates - presumably somewhere in that you have made a mistake.
With respect to your last post, what coordinate system is the formula in the screenshot specified in? And what is the meaning of ##\cos(\mathbf{n},x)##?
I computed projections of curl in new coordinate system (yz-plane is rotated by an angle 45 degrees about x-axis) using this formula:
##cos(n, x)## is cosin of angle between normal vector in new coordinate system(yz-plane is rotated by an angle 45 degrees about x-axis) and x-axis in old coordinate system.
Normal vector n is perpendicular to contour ##\Delta L## in new coordinate system (see my post#1).
The problem, then, is that this does not appear to be a vector expression. It produces a single number. Unless perhaps ##\partial\mathbf{v}_x/\partial y## is supposed to be interpreted as ##(\partial v_x/\partial y)\vec{\hat{x}}##?
It's interpreted as ##(\partial v_x/\partial y)\vec{\hat{x'}}##
In which case only partial derivatives of ##A_x## can multiply ##\vec{\hat{x}}'##. That doesn't seem plausible, particularly if you consider that the trivial case (##\vec{\hat{x}}=\vec{\hat{x}}'## etc) would not be an identity.
I think you are misunderstanding something in your text.
