C/C++ What is the difference between cin and getline in C++?
  • Thread starter Thread starter JonnyG
The discussion revolves around a C++ program designed to store and retrieve recipes, highlighting an issue with input handling. The user initially encounters a problem where the program does not allow for input after prompting for a recipe name, leading to confusion. The root cause is identified as the use of `cin >>` for input, which reads until whitespace and leaves the newline character from the previous input in the buffer. This leftover character causes the subsequent `getline` call to read an empty string.To resolve this, the recommendation is to use `cin.ignore()` to clear the input buffer before calling `getline`. Clarifications are made regarding the behavior of `cin`, emphasizing that it skips leading whitespace and reads until it encounters another whitespace character. The discussion also touches on the behavior of input in loops and the nuances of how different whitespace characters are treated, such as spaces and newlines. Overall, the conversation provides insights into effective input handling in C++ and the importance of managing the input buffer correctly.
JonnyG
I am writing a small practice program to store and retrieve recipes using c++. I ran into a weird problem and I can't seem to figure out the cause of it. Check out this code:
Here is a source file:
[CODE lang="cpp" title="Recipes.cpp"]string getInitialChoice() {
string choice;
cout << "Do you want to store a recipe or retrieve a recipe (s for store, r for retrieve)? " << endl;
cin >> choice;
return choice;
string getRecipeName() {
cout << "Enter recipe name: ";
string recipeName;
getline(cin, recipeName);
return recipeName;
}[/CODE]Here is my main function:
[CODE lang="cpp" title="main.cpp"]int main() {
string choice = getInitialChoice();
if (choice == "s") {
getRecipeName();
}[/CODE]
When I run the program this is the output:
Do you want to store a recipe or retrieve a recipe (s for store, r for retrieve)? s
Enter recipe name: Press any key to continue . . .
Notice that it didn't give me any chance to enter the recipe name? It just reads in a blank space. I was able to fix this by going back to my function getInitialChoice() and changing the cin >> choice to getline(cin, choice), but I don't see why that should make a difference? The difference between cin and getline, as far as I know, is that cin will read up until it encounters a whitespace whereas getline will read up until it encounters a newline. Can someone please explain what's happening there?
Technology news on Phys.org
I hope I am right as I learn C++ not long ago and still learning here. I encountered this before, the reason is in the first cin, it read until the null character and stop. the null is still in the stream. The next cin will read the null that was left by the last one and just skip.
The way to fix it is put cin.ignore() before the next cin.
Likes JonnyG
This works. Thank you.
No, that isn't what happens at all. The stream input operator, >>, reads up to the first whitespace character, not the null character.
In the case of the program posted above, when the user is asked to choose an operation, typical responses would be s <ENTER> or r <ENTER>. It is the ENTER key that is still in the input buffer waiting for the next input operation. A call to cin.ignore() gets rid of that character.
Likes Vanadium 50, yungman and JonnyG
Yes, I was wrong, it's the space.
yungman said:
it's the space.
No, it's more likely the ENTER character, which is different from the space character. Both are kinds of whitespace, along with the tab character.
Likes Vanadium 50
Suppose I have the code:
string in;
while (cin >> in) {
cout << in;
Now suppose I first enter test1 <ENTER> . Then cin reads test1 then stops because it encounters the whitespace (<ENTER>). That whitespace is left in the buffer. Now on the next iteration of my while loop, suppose I enter test2 <ENTER> . After I hit the ENTER key, the buffer is holding: whitespace, test2, whitespace (the first whitespace being left over from the first iteration of my while loop). Since cin stops reading as soon as it encounters a whitespace, which in this case would be the first character in the buffer, how does cin read in test2? (I believe this code works, but from what I understood of your previous explanation, it shouldn't).
string in;
while (cin >> in) {
cout << in;
cin doesn't read anything, and cout doesn't write anything. Both of these are just stream objects, input stream and output stream, respectively.
The actual reading is done by the extraction operator >> (extracting from a stream), and writing is done by the insertion operator << (inserting into a stream).
The extraction operator >> skips leading whitespace and reads subsequent characters until it hits a whitespace character. From the Visual Studio docs for this operator:
The operator skips the leading white spaces unless the skipws flag is set. It reads all the following characters until the next character is a white space or the end of the file is reached.
In the code above if you type abc <TAB>pdq<SPACE>xyz<ENTER>, the output line looks like this after three iterations of the loop:
abcpdqxyz
In the first input, in is abc. For some reason the first output writes it on the next line.
The next input skips the TAB character, and in becomes pdq, which is written following the first output.
The next input skips the SPACE character, and in become xyz, which gets written following the previous output.
The only thing that I don't quite understand is why the first output starts on a next line.
I just whipped up this little program, why this work? I can type name in the first two, and single character in the second two and works without cin.ignore().
C++:
#include <iostream>
using namespace std;
int main()
{    const int csize = 51;
    char Cr[csize]; char C;
    cout << "Enter first line:  ";
    cin >> Cr; cout << endl;
    cout << " The first line is: " << Cr << endl;
    cout << "Enter second line:  ";
    cout << " The second line is: " << Cr << endl;
    cout << "Enter first letter:  ";
    cin >> C; cout << endl;
    cout << " The first char is: " << C << endl;
    cout << "Enter second char:  ";
    cout << " The second char is: " << C << endl;
    return 0;
  • · Replies 118 ·
9K
  • · Replies 41 ·
  • · Replies 65 ·
