Problem with easy diffrential equation
  • Thread starter Thread starter TheNaturalStep
    Diffrential
2 replies · 5K views · last reply
TheNaturalStep
Problem with an easy diffrential equation, the problem is explained in the picture ...
http://img209.imageshack.us/img209/7341/diffproblemsf9.jpg
Kindly TNS
You have
[tex]\frac{dm_p}{dt}= \dot{m_p_i}[/tex]
In that case
[tex]m_p= \dot{m_p_i}t[/tex]
would be correct only if [itex]\dot{m_p_i}[/itex] was a constant.
First, check out https://www.physicsforums.com/showthread.php?t=8997
So you can type the math notation in [itex]\LaTeX[/itex].
To see how I typed things in the "math" click on the images and you will see the code. It's very easy, and the preferable way to communicate.
Second,
So your equation is:
[tex]\frac{d m_p}{dt}= m_{pi}[/tex]
Now your teacher says that [itex]m_p = m_{pi}t[/itex].
You are saying this:
Let [itex]m_{pi} = m t^4[/itex].
Then,
[tex]m_p = \frac{m_{pi} t}{5}[/tex]
You are not consistent with your notation. You should be careful here. For example, you introduce the variable [itex]m[/itex] and then it just disappears. However, with your argument you have:
Original:
You:
[tex]m_{pi} = m t^4[/tex]
If we sub this in:
[tex]\frac{d m_p}{dt} = (m t^4)[/tex]
Now you say:
What happens if you differentiate this?
[tex]\frac{d m_p}{dt} = \frac{d \left( \frac{m_{pi} t}{5} \right)}{dt} = ?[/tex]
