Problem with this Java string program
  • Topic: Comp Sci
  • Thread starter Thread starter anyonebutangel
    Java Program String
12 replies · 3K views
anyonebutangel
java STRING program
no equations
Summary:: I'm having problem with this source code.we need to find the frequency of the number of words beginning with an UPPERCASE Alphabet in a sentence.
The data members and member method must be according to the question given in the document.
though i could compile it but it's giving runtime error for STRING INDEX OUT OF BOUNDS EXCEPTION. I hope someone can help me point out where I'm missing the error.
Java:
/*Question:
A class Capital has been defined to check wether a sentence has words beginning with a capital latter or not.
Some of the members of the class are given below:
Class name                :    Capital
Data members/instance variables    :
sent                    :    to store the sentence
freq                    :    stores the frequency of words beginning with a capital                             letter
Member functions/methods        :
Capital()                :    default constructor
void input()                :    to accept the sentence
Boolean isCap(String w)            :    checks and returns true if the word begins with a capital letter .
Specify the class Capital giving details of the constructor, void input(),Boolean isCap(String w) and void display().Define the main() function to create an object and call the function accordingly to enable the task.
import java.io.*;                                        //importing package
class Capital
String sent;                                        //global data members
int freq,l;
Capital()                                            //constructor
sent="";
freq=0;
void input()throws IOException
BufferedReader br=new BufferedReader(new InputStreamReader(System.in));                //creating object "br" for input
System.out.println("ENTER THE SENTENCE");
sent=br.readLine();
l=sent.length();                                        //variable "l" stores the length of the string
boolean isCap(String w)                                    //boolean function to check if word begins with an uppercase alphabet
if(w.charAt(0)>='A'||w.charAt(0)<='Z')
return(true);
else
return(false);
void display()
int j=0;
System.out.println("THE SENTENCE ENTERED IS:"+sent);
for(int i=sent.indexOf(' ');i<l;i++)
while(sent.charAt(i)==' ')                                //while loop to count the frequemcy of words beginning with capital letters
if(isCap(sent.substring(j,i))==true)
freq++;
j=i+1;
System.out.println("THE NUMBER OF WORDS BEGINNING WITH UPPERCASE ALPHABET IS:"+freq);
}                                            //end of display()
public static void main(String args[])throws IOException
Capital ob=new Capital();
ob.input();
ob.display();
}                                            //end of main()
}                                            //end of class
That means you have tried to access a character that is beyond the end of a string.
If you want anyone to look at your code please post it inside [code=java]...[/code] tags.
I've posted it as a text document both question and the code
will that do?
Splitting a string into substrings based on the occurrence of a particular character is a common task for which there is a library function:
Java:
   String[] words = sent.split(' ');
This will probably solve your indexing error, because you will then only need to check the first character of each word.
You can replace isCap with
Java:
public boolean isCap(String w)
   return w.charAt(0) >= 'A' && w.charAt(0) <= 'Z';
or, even better because it correctly handles things like 'Å',
Java:
   return Character.isUpperCase(w.charAt(0));
Java:
Java:
Java:
this program is a part of school project so I'm supposed to solve this in accordance to the syllabus prescribed and as i mentioned in the thread it must be strictly in accordance to the question that preceeds the code we have to use the same member method and data members and library functions are still not included in the syllabus..we cannot manipulate the names of method.Kindly help me point out why is it giving the STRING INDEX OUT OF BOUNDS EXCEPTION.
jedishrfu said:
What if the string has no spaces? What does the index function return?
according to the question we have to assume that.
if it was not for the question,I agree with you that this point about white space character should be considered.
The error message tells you that something is wrong when you call the substring method in line 52. Try inserting the following line before line 52:
Java:
        System.out.println("j = " + j + ", i = " + i);
which will show you what is wrong, then work out how i and j have acquired these values.
My post was a hint as the index function returns a -1 when there are no spaces and so youve set your i variable to -1 with the possible and likely subsequent fail you observe.
You should test for it and decide what to do.
Let's take a closer clook as display().
Java:
void display()
   int j=0;
This really needs a name which describes its purpose.
Java:
            freq++;
            j=i+1;
This is your problem. As written, the for loop starts at a point where sent.charAt(i) is a space. Which means that the condition in the while loop is always true. Which means that j will eventually exceed i, which is probably what substring is objecting to.
A while loop where the condition does not depend on a variable modified by the loop and which has no explicit break statement is asking for trouble.
I can't work out what your loop is supposed to be doing, because your intended algorithm is not clear to me.
I would suggest this: Have a variable which stores the position of the first character of the current word (and call it something meaningful, such as wordStart. If you don't have a current word yet, set this to something obviously invalid like -1.
A word begins when you don't have a current word and you reach a character which is not a space.
A word ends when you reach a character which is either a space or the last character in the string.
You don't need to track the end of the word; all you need to pass to isCap is the "word" consisting of the first letter of the current word (ie. sent.substring(wordStart,wordStart)).
Start at the beginning of the string and work through until you reach the end. Whenever you reach the end of a word, process that word and then set wordStart = -1.
Java:
Java:
Java:
thanks your idea helped greatly i did that and saw that i needed to change while with if but encountered a problem that the program wouldn't consider the last word as last character isn't the whitespace.so i did it using StringTokenizer.
I'M UPLOADING THE SNIP OF CHANGES AND OUTPUT IN CASE ANYONE WANTS TO HAVE A LOOK AT IT.
BUT MORE SUGGESTIONS ARE ALWAYS WELCOME
Java:
Java:
Java:
thanks for your help.I came up with StringTokenizer and it's working fine now.
