Problems between Quantum Mechanics and General Relativity
The discussion centers on the incompatibilities between quantum mechanics and general relativity, exploring theoretical frameworks, challenges in quantization, and potential resolutions. Participants examine concepts such as background independence, renormalization, and the implications of the Standard Model in the context of general relativity.
  • Some participants note that general relativity (GR) and quantum mechanics (QM) are fundamentally incompatible, with GR being problematic when quantized.
  • One participant mentions that quantum field theory typically operates in flat spacetime and struggles to achieve a quantum theory of gravity that is background independent.
  • Another participant argues that string theory, a leading approach, is not background independent, although it is suggested that this does not invalidate the theory entirely.
  • Concerns are raised about the renormalization of GR when treated as a field theory, with participants noting it is only effective up to a certain energy scale.
  • Some participants propose that modifying the Standard Model (SM) to allow for particles with spatial extent or altering GR to eliminate singularities could be potential solutions to compatibility issues.
  • One suggestion involves smearing particles across their Compton wavelength to address the point particle issue in the context of GR.
Participants express multiple competing views regarding the compatibility of quantum mechanics and general relativity, with no consensus reached on the best approach to resolve the issues discussed.
Discussions include references to specific texts and theories, such as Zee's books and Relational Mechanics, but limitations in understanding and the current state of research are acknowledged.
PabloAMC
I have read several times that general relativity has some problems with quantum mechanics and they are not compatible. However, special relativity can be introduced in quantum mechanics mainly by Dirac equations (so I am pretty sure that the problem of passing from a frame where the parameter is time to one where the parameter is the proper time τ, and spacetime is 4 dimensional should not be a problem. I have had two degree subjects in quantum mechanics and one in general relativity. In this last one it was stated that in order to change from special relativity to general relativity no curvature terms should be added, but we should change the partial derivatives, by covariant derivatives (using Christoffel symbols).
So, taking all into account, does anyone know any mathematically expressed explanation of where is this problem? (It sounds to me something about renormalization, but I cannot say)
Thanks in advance
Almost all of the machinery of quantum field theory is based on a flat space-time. This can be taken over to curved space-time "background" but doesn't lead to a quantum theory of gravity. A true theory is expected to be background independent. I think no one knows how to do this. Attempts based on a weak or linearized theory have issues with too many (an infinite number) of renormalization constants. I'm kind of a fossil in this regard and haven't kept up with the literature so things may be different now.
Thanks a lot. However, unless I am wrong, I think that one of the main approaches (string theory) is not background independent
With like 10^27 (not an accurate number and based on hearsay) different vacuum states it's unlikely they can really make the claim of background independence. I have a real hard time referring to string theory as a theory.
Its current formulation isn't. But that doesn't kill a theory. E.g., Fierz-Pauli theory is also background dependent, but you can iterate it to GR, which is background independent.
The problem is indeed that if you regard GR as a field theory and quantize it, it is not renormalizable. This means it can only be trusted up to a certain energy scale, and hence is 'only' effective. But there are other problems in the quantization of GR. E.g., Zee's book on GR treats them somewhere at the end of the book.
Do you know where I can find a text describing that?
The book you are referring to is Einstein Gravity in a nutshell, isn't it?
Yes. That book, and zee's qft book, are good resources.
Thanks a lot. I'll take a look
While on the topic, It may be useful to look into Relational Mechanics as well. See Relational Mechanics and Implementation of Mach’s Principle with Weber’s Gravitational Force by Andre Koch Torres Assis
Another way that the Standard Model and general relativity are not compatible is that the Standard Model treats all of its fundamental particles as point masses which create black hole singularities in GR.
do you have any ideas on how to solve this? i.e modify SM to give particles spatial extent or modify GR to remove singularities?
If you retain classical GR, one solution would be to smear particles across their Compton wavelength or Heisenberg uncertainty under QM so that they would cease to be point particles; if you moved to a graviton formulation of GR, there wouldn't be any true singularities in GR.
  • · Replies 40 ·
  • · Replies 71 ·
  • · Replies 37 ·
  • · Replies 24 ·
10K
