Product of two consecutive integers
9 replies · 5K views · last reply
nobahar
Prove that [tex]n^2+n[/tex] is even. Where n is a positive integer.
[tex]n^2+n[/tex]
[tex]n^2+n = n(n+1)[/tex]
One of which must be even, and therefore the product of 2 and an integer k.
[tex]n = 2k, \left \left 2*(k(n+1))[/tex]
or
[tex]n+1 = 2k, \left \left 2*(n*k)[/tex]
Is there a better way of doing this? I read this is not an inductive proof; what would this entail?
Many thanks in advance.
This looks absolutely fine. No need for induction at all.
As rochfor1 said, that is a perfectly good proof and simpler than "proof by induction".
But since you ask, here goes:
If n= 1, then [itex]n^2+ n= 1^2+ 1= 2[/itex] which is even.
Now, suppose that [itex]k^2+ k[/itex] is even and look at [itex](k+1)^2+ (k+1)[/itex]
[itex](k+1)^2+ (k+1)= k^2+ 2k+ 1+ k+ 1[/itex][itex]= (k^2+ 2k)+ 2k+ 2[/itex]. By the induction hypothesis, [itex]k^2+ k[/itex] is even and so [itex]k^2+ k= 2m[/itex] for some integer m (that is the definition of "even") so [itex](k+1)^2+ (k+1)= (k^2+ 2k)+ 2k+ 2[/itex][itex]= 2m+ 2k+ 2= 2(m+k+1)[/itex]. Since that is "2 times an integer", it is even.
Having proved that the statement is true for 1 and that "if it is true for k, it is true for k+1", by induction, it is true for all positive integers.
Yet a third way: If n is a positive integer, it is either even or odd.
case 1: n is even. Then n= 2m for some integer m. [itex]n^2= 4m^2[/itex] so [itex]n^2+ n= 4m^2+ 2m= 2(m^2+ m)[/itex]. Since that is 2 times an integer, it is even.
case 2: n is odd. Then n= 2m+ 1 for some integer m. [itex]n^2= (2m+1)^2= 4m^2+ 4m+ 1[/itex] so [itex]n^2+ n= 4m^2+ 4m+ 1+ 2m+ 1[/itex][itex]= 4m^2+ 6m+ 2= 2(2m^2+ 3m+ 1)[/itex]. Again that is 2 times an integer and so is even.
Simple reasoning is needed.
For two consecutive integer , one will be even and another will be odd.
Thus;
[tex]n\equiv0(mod 2)[/tex]
and
[tex]n+1\equiv1(mod 2)[/tex]
We may now conclude that [tex]n(n+1)\equiv0(mod 2)[/tex] and means that n²+n is even.
Handwritten-style typed proof by induction that n squared plus n is always even: P1 = 2 times 1 holds, assume Pk = k squared plus k = 2m, then P(k+1) = k squared plus 3k plus 2 = 2(m + k + 1), so P n holds for all positive integers.
  • Handwritten-style typed proof by induction that n squared plus n is even: P1 = 2 x 1 holds, assume Pk = k squared + k = 2m, then P(k+1) = k squared + 3k + 2 = 2(m + k + 1), so Pn holds for all positive integers.
If n is odd, n^2 is odd. If n is even, n^2 is even. odd+odd=even and even+even=even.
OP: Why do you want a proof by induction? The proof you gave is simple and beautiful.
What you say is true, but you can't ascertain which of them will be even and which will be odd. In what follows, you are assuming that n is even and n+1 is odd. That is one of two possible cases, so you work is not complete.
icystrike said:
Thus;
and
yes that is true. for the other case , it can be proved analogously .
