Product of two propagators U(-t)U(t) in coord representation
The discussion revolves around the properties of the product of two propagators in quantum mechanics, specifically the expression ##\hat{U}(-t)\hat{U}(t)## and its implications in the coordinate representation. Participants explore the resulting phase factors and the nature of the Dirac delta function when multiplied by these factors, addressing both theoretical and mathematical aspects.
  • One participant asserts that ##\hat{U}(-t)\hat{U}(t) = \hat{I}##, leading to the expectation that ##\left\langle x\right|\hat{U}(-t)\hat{U}(t)\left|x^\prime\right\rangle = \delta(x-x^\prime)##, but finds a phase factor instead.
  • Another participant questions the derivation of the phase factor and suggests re-expressing functions multiplied by the delta function.
  • Phase factors for specific cases are proposed: for a free particle, ##\phi(x,x^\prime) = \dfrac{m\left(x^2-x^{\prime 2}\right)}{2t}##; for a harmonic oscillator, ##\phi(x,x^\prime) = \omega\left(x^2-x^{\prime 2}\right)\cot\omega t##.
  • Participants discuss the implications of multiplying a delta function by a phase factor and whether it retains the properties of a delta function.
  • Concerns are raised about the validity of certain properties of the delta function when discontinuities are present in the functions involved.
  • One participant emphasizes the importance of using smooth functions when working with distributions, noting that non-smooth functions can lead to different results.
Participants express differing views on the nature of the delta function when multiplied by phase factors, with some asserting it retains its properties while others question this under certain conditions. The discussion remains unresolved regarding the implications of discontinuities and the behavior of distributions.
Participants highlight the need to consider the smoothness of functions when discussing distributions, indicating that certain mathematical properties may not hold if the functions involved are not smooth.
souda64
Here is a mystery I'm trying to understand. Let ##\hat{U}(t) = \exp[-i\hat{H}t]## is an evolution operator (propagator) in atomic units ([itex]\hbar=1[/itex]). I think I'm not crazy assuming that ##\hat{U}(-t)\hat{U}(t)=\hat{I}## (unit operator). Then I would think that the following should hold
[tex]\left\langle x\right|\hat{U}(-t)\hat{U}(t)\left|x^\prime\right\rangle = \left\langle x\right|\hat{I}\left|x^\prime\right\rangle = \left\langle x|x^\prime\right\rangle= \delta(x-x^\prime)[/tex]
However, when using the resolution of identity in the coordinate representation ##\hat{I}=\int\left|y\rangle\langle y\right|dy## and well known expressions for propagators (for free particle or harmonic oscillator) in the coordinate representation, I get a coordinate dependent phase factor in front of the delta function:
[tex]\left\langle x \right | \hat{U}(-t)\hat{U}(t) \left | x^\prime\right\rangle = \int dy\left\langle x\right|\hat{U}(-t)\left|y\right\rangle\left\langle y\right|\hat{U}(t)\left|x^\prime\right\rangle = e^{i\phi(x,x^\prime)}\delta(x-x^\prime)[/tex]
Could someone, please, comment on that? I'm lost although something tells me the explanation must be trivial.
THANKS!
P. S. The integral over y becomes a Fourier integral, so you can easily verify all this.
You do not explain how you get the phase factor or what its expression is. I also suggest you think about how you can reexpress ##f(x)\delta(x-a)## in general.
I get the following phase factors (##e^{i\phi(x,x^\prime)}##)
Free particle with mass ##m##: $$\phi(x,x^\prime) = \dfrac{m\left(x^2-x^{\prime 2}\right)}{2t}$$
Harmonic oscillator with frequency ##\omega##: $$\phi(x,x^\prime) = \omega\left(x^2-x^{\prime 2}\right)\cot\omega t$$
So why do you think that this gives a phase factor? Did you read the second part of my post?
Thanks a lot for your input! I'm still confused though... What do you mean by "reexpressing ##f(x)\delta(x-a)##"? The product ##e^{i\phi(x,x^\prime)}\delta(x-x^\prime)## is still NOT a delta function, even if ##\phi(x,x)=0##. What am I missing?
Yes it is. It is a delta function regardless of what ##\phi(x,x)## is (although with a different phase if it is non-zero). You are missing a very basic property of the delta function.
To give you a hint: what is the defining property of the delta function (or more correctly, the delta distribution)?
Okay, I see now what you mean. You mean that as long as $$\int\limits_{-\infty}^{\infty} f(x) \psi(x-a)dx = f(a)$$ for any f(x), the distribution ##\psi(x-a)## is a delta function (distribution). So, you mean that a delta function multiplied by an arbitrary phase factor ##e^{i\phi(x)}## is still a delta function. Well, what about a function (distribution) ##\tilde{\delta}(x-a) = (x-a+1)\delta(x-a)##. Obviously, this function still has a sifting property and its integral over the real axis is one. Is it also a delta function (distribution)?
I guess, I'm taking back the last argument about ##(x+1)\delta(x)## simply because ##(x+1)\delta(x) = x\delta(x) + \delta(x) = \delta(x)## because ##x\delta(x) = 0##. So, the Dirac delta function actually absorbs any phase factor ##e^{i\phi(x)}## with ##\phi(0)=0##. Right? As to the coordinate representations of the propagators, is it well known? And if it is, where can I read about it? Thanks a lot for your replies!
Yes, or more generally: ##f(x)\delta(x-a) = f(a) \delta(x-a)##.
Really? I always thought it's true only if you integrate over ##x## (sifting property)... If that is always true, that resolves the problem with coordinate representation of the propagators. But I still feel a bit uncomfortable about the whole thing. Thanks though!
Remember that a delta function centered at ##x=a## has zero value everywhere outside this point, this means in an expression like ##f(x)\delta(x-a)##, ##f(x\neq a)## is superfluous as it will be multiplied with zero anyway.
Thanks! That makes sense... However, if ##\delta(x)## is understood as a distribution, then the sifting property should work only when calculating an integral with the distribution, and this is a part of definition of ##\delta(x)## distribution. Otherwise, what if ##f(x)## in your example has a discontinuity at ##x\neq a##? Will then ##f(x)\delta(x-a) = f(a)\delta(x-a)## still hold?
Anyways, I feel much better now thanks to you. So, thank you for your time!
Here is something I wanted to point out. Your suggestion that ##f(x)\delta(x-a)=f(a)\delta(x-a)## should imply that $$\frac{d}{dx}\left[f(x)\delta(x-a)\right]=f(a)\delta^\prime(x-a)$$ which is not true for any (even smooth) function ##f(x)##. A simple example is ##f(x)=\sqrt{x-a}+1##: $$\frac{d}{dx}\left[\left(\sqrt{x-a}+1\right)\delta(x-a)\right] = \frac{1}{2}(x-a)^{-\frac{1}{2}}\delta(x-a) + \left(\sqrt{x-a}+1\right)\delta^\prime(x-a) \neq \delta^\prime(x-a)$$ I'm sure I can come up with many other examples of smooth and maybe even infinitely smooth functions.
Heh, this is an example of how (when working with distributions) one must keep in mind the particular rigged Hilbert space structure involved. E.g., in your example, f(x) is not a Schwartz function.
Distributions are only defined on smooth functions, so this problem cannot occur.
Your function is not smooth at ##x=a##. If you really used a smooth function, then these would actually be the same distribution, although it wouldn't be apparent from the expression. If you would evaluate them on a test function (smooth function with compact support), you would get exactly the same result.
One is allowed to multiply any distribution by more general functions, since the multiplication is defined by ##(hD)(f) = D(hf)##, so we only need to make sure that ##hf## is again a test function (for any test function ##f##). In fact, one is allowed to multiply by any smooth function, but the result might happen to be just a distribution and not a tempered distribution anymore.
In addition to what has already been said, you cannot just take a function which is not differentiable and act as if its distributional derivative is given by the derivative away from the points where it is not. With this logic, the derivative of the Heaviside function would be zero, which is not the case.
If you are not sure of how to differentiate something, go back to the definition of the derivative of a distribution: ##f'[\varphi] = - f[\varphi']##.
Well, let's clarify the issue with the derivative. Of course, all equations have to be read as equations in the sense of distributions. So let's do it carefully.
First we start with the naive application of the rules and pretend that we can naively treat the ##\delta## disribution like a function. Of course, as already stated, the function ##f## must be differentiable at ##x=a##. Then we have in the naive way
$$\frac{\mathrm{d}}{\mathrm{d} x} [f(x) \delta(x-a)]=f'(x) \delta(x-a)+f(x) \delta'(x-a)=f'(a) \delta(x-a) + f(x) \delta'(x-a).$$
Now let's prove that this is justified. To that end we have to apply the distributions on the left and the right side of the equation to a test function (which is, e.g., ##\phi \in C_0^{\infty}(\mathbb{R},\mathbb{C})##). So the left-hand side is
$$\int_{\mathbb{R}} \mathrm{d}x \frac{\mathrm{d}}{\mathrm{d} x} [f(x)\delta(x)]\phi(x):=-\int_{\mathbb{R}} f(x) \delta(x-a) \phi'(x) = -f(a) \phi'(a).$$
Now let's evaluate the right-hand side:
$$\int_{\mathbb{R}} \mathrm{d} x [f'(a) \delta(x-a) + f(a) \delta'(x-a)] \phi(x)=f'(a) \phi(a) -\int_{\mathbb{R}} \mathrm{d} x \frac{\mathrm{d}}{\mathrm{d} x} [f(x) \phi(x)] \delta(x-a)=f'(a) \phi(a) - f'(a) \phi(a)-f(a) \phi'(a)=-f(a) \phi'(a).$$
So the above naive calculation is correct.
The funny thing is that also the other suggested way is right too:
$$\mathrm{d}{\mathrm{d} x} [f(x) \delta(x-a)] = \mathrm{d}{\mathrm{d} x} [f(a) \delta(x-a)] =f(a) \delta'(x-a),$$
because when evaluating the right-hand side of this applied to a test function gives also the right result:
$$\int_{\mathbb{R}} \mathrm{d} x f(a) \delta'(x-a) \phi(x)=-f(a) \phi'(x).$$
Of course, it is crucial to realize that always
$$f(x) \delta(x-a)=f(a) \delta(x-a)$$
but that on the other hand
$$f(x) \delta'(x-a) \neq f(a) \delta'(x-a).$$
The product rule even holds for all distributions, not just ##\delta##. A proof can be found in Gelfand, Shilov, Generalized functions vol.1.
Well, the phase factor ##e^{i\phi(x)}## is not a Schwartz function either. I think that the rest of this conversation (thanks to all contributors) resolves the "problem" with the relation ##f(x)\delta(x)=f(a)\delta(x)## which is valid for all distributions but not necessarily for all tempered distributions (which is wider class). The key is in the following quote:
rubi said:
One is allowed to multiply any distribution by more general functions, since the multiplication is defined by (hD)(f)=D(hf), so we only need to make sure that hf is again a test function (for any test function f). In fact, one is allowed to multiply by any smooth function, but the result might happen to be just a distribution and not a tempered distribution anymore.
So, keeping in mind the definition of the multiplication of the distribution with a function, one can multiply the distribution with a function which is not necessarily smooth and compact but as long as the new test function is still smooth and compact, everything is fine and the relation ##f(x)\delta(x)=f(0)\delta(x)## holds. In that sense, the phase factor ##e^{i\phi(x)}## is smooth but not compact (also not Schwartz), but it works because the product of it with any smooth and compact function is smooth and compact. So, to summarize:
$$e^{i\phi(x)}\delta(x) = \delta(x),\,\,\,\,\,\,\text{if}\,\,\phi(0)=0$$
And finally, going back to the original question
souda64 said:
$$\left\langle x\right|\hat{U}(-t)\hat{U}(t)\left|x^\prime\right\rangle = \int\limits_{-\infty}^{\infty}dy\left\langle x\right|\hat{U}(-t)\left|y\right\rangle\left\langle y\right|\hat{U}(t)\left|x^\prime\right\rangle = e^{i\phi(x,x^\prime)}\delta(x-x^\prime) = \delta(x-x^\prime)$$
I conclude that the above is nice and clean because for both free particle and harmonic oscillator propagators one has ##\phi(x,x^\prime) = 0## when ##x=x^\prime##.
I hate to be annoying but what is the deal with Boltzmann operators (obtained from propagators by replacing ##t\rightarrow-i\beta\hbar##) then:
\left\langle x\right|\hat{U}(i\beta\hbar)\hat{U}(-i\beta\hbar)\left|x^\prime\right\rangle = \int\limits_{-\infty}^{\infty}dy\left\langle x\right|\hat{U}(i\beta\hbar)\left|y\right\rangle\left\langle y\right|\hat{U}(-i\beta\hbar)\left|x^\prime\right\rangle = \text{(divergent)}
The class of tempered distribution is actually a smaller class (i.e. every tempered distribution is a distribution). For the delta distriibution, however, the relation you mentioned works for all smooth functions ##f##, in the sense that the resulting distribution is not just a distribution, but even a tempered distribution.
The criterion on the function ##f## is precisely that it needs to be smooth. If it is smooth, then certainly ##f\varphi## is smooth and compactly supported again for any smooth, compactly supported ##\varphi##. If ##f## is not smooth, then you can easily find test functions such that ##f\varphi## is not smooth either. For tempered distributions, you additionally need some growth condition on ##f##. However, all of this holds for general distributions. If you are only interested in ##\delta##, you don't need to worry about it.
So, to summarize:
Technically, ##\phi(0)## could also be any integer multiple of ##2\pi##.
For imaginary time, ##U(t)## (if it is well-defined in the first place) isn't necessarily bounded anymore, so it's not surprising that it isn't defined on all states and leads to divergencies.
