Program not outputting data from file into 2D array in Dev-C++
  • Topic: Comp Sci
  • Thread starter Thread starter Dembadon
    File Troubleshooting
1 reply · 3K views
Dembadon
I am trying to write a quick program that will let me experiment with some different file I/O functions. I want to practice taking data from a file, loading it into a 2D array, then performing some analysis on the data obtained from the file.
I have created a .txt file with some sample data, but I am not getting output when I run the program.
I am using Dev-C++ as my compiler.
Contents of the text file, which I have named "testfile.txt":
Code:
1, 1, 23
0, 2, 22
0, 3, 55
1, 4, 10
1, 5, 3
1, 6, 44
0, 7, 23
1, 8, 25
1, 9, 22
0, 10, 26
1, 11, 27
1, 12, 99
0, 13, 62
1, 14, 45
The first value for each line indicates whether the data values that follow are good. Zero indicates bad data, while 1 indicates good data. I am calling the second data value on each line time, and the third speed.
Here is my program:
Code:
// Headers ////////////////////////////////////////////////////////////////////
#include <iostream>
#include <fstream>
   using namespace std;
// Global Constants //////////////////////////////////////////////////////////
   const int MAX_STR_LEN = 80;
   const int MAX_ROWS = 50;
   const int MAX_COLS = 2;
   const int TIME = 0;
   const int SPEED = 1;
   const char COMMA = ',';
// Funtion Prototypes ////////////////////////////////////////////////////////
process: obtains good data from file: first value for each line in the file
         indicates if the data is good or not. 1 = good, 0 = bad
input: data array to be created, file name, number of good data lines
output: upload success or failure, number of rows in final array (by reference)
dependencies: fstream
bool uploadData( int data[][ MAX_COLS ], char fileName[], int &size );
process: prints data that has been stored by uploadData to the screen as it appears
         in the file
input: data array, size of data array, time and speed values (columns)
void displayData( int data[][ MAX_COLS ], int numData, int numCols );
// Main Function //////////////////////////////////////////////////////////////
int main()
    // initialize function/variables
    char fileName[ MAX_STR_LEN ];
    int data[ MAX_ROWS ][ MAX_COLS ];
    int numData = 0;
    // prompt user for file name
    cout << "Please enter filename: ";
    cin >> fileName;
    // check for bad file name
    if( !uploadData( data, fileName, numData ) )
        cout << "ERROR: Data upload failed - Program aborted." << endl;
        cout << "Please check the file name and try again." << endl;
        system( "pause" );
        return 0;
    // output data to console
    displayData( data, numData, MAX_COLS );
    // hold screen for user
    system( "pause" );
    return 0;
// Supporting Functions ///////////////////////////////////////////////////////
    int rowIndex = 0, badSpeed, badTime, numData = 0, testVal;
    bool success = false;
    char dummyChar;
    ifstream fin;
    // clear and open file
    fin.clear();
    fin.open( fileName );
    // test for a good filename
    if( fin.good() )
        // prime loop
        fin >> testVal >> dummyChar;
        // loop through the file
        while( fin.good() )
            // test for good data value
            if( testVal == 1 )
                // grab rest of line and assign to array postions
                fin >> data[ rowIndex ][ TIME ] >> dummyChar;
                fin >> data[ rowIndex ][ SPEED ];
                // increment rowIndex
                rowIndex++;
                // set success flag
                success = true;
            // otherwise skip line in the file
            else
                fin >> badTime >> dummyChar >> badSpeed;
            // attempt to read more data
        // end loop
    // set size
    numData = rowIndex;
    // close file
    fin.close();
    // return success
    return success;
    int rowIndex, colIndex;
    // loop through the rows
    for( rowIndex = 0; rowIndex < numData; rowIndex++ )
        // loop through the columns
        for( colIndex = 0; colIndex < MAX_COLS; colIndex++ )
            // output comma-separated values to the screen
            cout << data[ rowIndex ][ TIME ] << COMMA;
            cout << data[ rowIndex ][ SPEED ] << endl;
Just figured out what was going on. My reference parameter for the size of my 2D array is mislabeled. :redface:
Edit: Also just realized the 2nd for loop in my display function is completely superfluous and causing double output. :redface:2
