Projectile Launching Problem. Solve with kinematics
The problem involves a projectile motion scenario where a cow is launched from a catapult, requiring the calculation of its initial speed given its horizontal distance traveled and vertical drop. The subject area is kinematics, focusing on the equations of motion for projectiles.
  • Mixed
  • Participants discuss the breakdown of the projectile's motion into horizontal and vertical components, questioning the use of trigonometric functions in calculating displacements and velocities. There is uncertainty regarding the relevance of mass in a kinematic context, and some participants suggest using specific equations to express time of flight and link horizontal and vertical motions.
Participants are exploring various methods to approach the problem, with hints provided regarding the use of kinematic equations. There is acknowledgment of the complexity involved in deriving the necessary expressions, and some participants express a willingness to refine their approaches based on ongoing discussion.
Participants note that the problem may lead to messy calculations, and there is an emphasis on ensuring the correct application of kinematic equations without reliance on forces, as per the homework constraints.
DeerHunter
A cow, with a mass of 327 kg, if fired from a medieval catapault, and travels a horizontal distance of 1375 m. It lands in a depression 39 m below its starting position. If it is launched at an angle of 37.0[tex]\circ[/tex] above the horizontal, find its initial speed.
Givens
HOR
[tex]\Delta[/tex] dx= 1375
V1x= ?
ax= 0m/s2
v2x=v1x
VER
[tex]\Delta[/tex] dy= -39 m
v1y= ?
ay= -9.81m/s2
v2y=?
[tex]\Delta[/tex] T=?
[tex] v^2 = v_0^2 + 2 a \Delta x[/tex]
[tex] x = x_0 + v_0 t + (1/2) a t^2[/tex]
I multiplied my vertical and horizontal displacements by 39.0* (i.e. dx= 1375*cos37) but I am not sure if this is right or if I should only use that for the velocity's only. Also I am not sure where to go from here all relevant equations require at least v1x,v2x,v1y,v2y and/or t. One last thing, I am not sure how mass is to be used as I am suppose to solve with kinematics, not forces but I could be wrong. Any help is appreciated! Thanks!
"I multiplied my vertical and horizontal displacements by 39.0* (i.e. dx= 1375*cos37)"
I don't really understand what you're doing here. If you denote the initial speed as V and you know the angle of launch is 37 degrees, then the initial horizontal component of velocity is Vcos37. Likewise, the initial vertical component is Vsin37. I don't see why you need to multiply the range(horizontal displacement) by cos37.
Oh, and in your "Relevant equations", I think you meant your first eqn to be: v = v_0 + at.
As with most projectile motions questions, you use those equations on the x and y directions to obtain 2 expressions. You can then link these expressions together to obtain your answer.
I think the working out is going to get rather messy for this particular question though.
I am sorry, after I posted this I realized that this would do nothing. I just tried something because I was running out of ideas. My only other idea would be to use this equation for y as max height for v2y is 0 m/s. (Correct me if this is wrong)
[tex] <br /> v1y^2 = v_0^2 + 2 a \Delta x<br /> [/tex]
but eliminate v_0^2.
My hint would be to use:
v[tex]^{2}[/tex] = u[tex]^{2}[/tex] + 2(a)(s)
v = u + at
(Here , v = final velocity, u = initial velocity, a = acceleration, s = displacement)
on the vertical direction to find an expression for the time of flight. Alternately, you could use equation 2 directly to find the time but you'll need to solve a rather messy quadratic.
Then use equation 2 on the horizontal direction and everything should fall into place.
I believe the working out will become messy so if anyone has more elegant ways of doing it, please post.
v = u + at
Thank you very much!
What I did for here was make a equation for time of flight
dx=v1*cos37* t +1/2 at^2
1375=v1x*cos37*t
[tex]\Delta[/tex] t= 1372/v1*cos37
now that i have [tex]\Delta[/tex] t I have inserted it into my vertical equation so
dy=v1y*cos37* t +1/2 at^2
-39=v1*sin37*(1372/v1*cos37) + 1/2 (-9.81)(1372/v1*cos37)^2
Vsin37= -4.905(1372/v1*cos37)^2(-39) /(1372/v1*cos37)
I'm going to play around with this and update with new info. You're right in saying this is a messy equation haha. Thanks again!
  • · Replies 16 ·
