Projectile Motion: golf ball velocity to reach the green
A golfer needs to determine the initial velocity required to hit a golf ball at a 17-degree angle to reach a green 250 meters away, which is at the same height as the tee. Initial calculations using trigonometry and kinematic equations suggested a velocity of 132.34 m/s, but the correct answer is 66 m/s. The discussion highlights the importance of understanding the vertical displacement (dy) as zero since the ball lands at the same height. Participants emphasize solving simultaneous equations derived from both horizontal and vertical motion requirements. The conversation underscores the need for clarity in applying projectile motion principles to accurately calculate the required launch velocity.
gungo
A golfer strikes a golf ball at an angle of 17 degrees above the horizontal. With what velocity must the ball be hit to reach the green which is a horizontal distance of 250 m from the golfer? It is at the same height as the tee.
trig equations
v2^2=v1^2+2ad
d=v1(t)+1/2a(t)2
d=(v1+v2/2)t
Well I used trigonometry to find the dy (tan17*250) and I believe that's the maximum height...meaning v2y at that time is 0
So I have dy=76.43 m
a=-9.8m/s^2
v2y=0
I used v2^2=v1^2+2ad to find the initial velocity in the y direction and got 38.7
I plugged that into the equation d=(v1+v2/2)t to find time and got 1.975 seconds
For the x direction I know dx=250, a=0, and t=1.975 seconds
So I used d=v1(t)+1/2a(t)2 to find v1 but the a is 0 so the equation just ends up being d=v1(t) and I got the initial velocity in the x direction to be 126.59
I used pythagorean theorem to find the total velocity to be 132.34 m/s 17 degrees above the horizontal...but the answer is 66m/s 17 degrees above the horizontal.
use the range equation R = \frac{v_{0} ^{2}sin(2\theta)}{g}
gungo said:
dy (tan17*250)
Wouldn't that be the height by which the ball would fly over the green if there were no gravity?
That would certainly be simpler, but I prefer first to help the student fix the errors in the chosen method.
Sorry I don't understand
You have not posted a diagram, but I hope you drew one.
The launch angle is 17 degrees and the length of the hole 250m. To reach a height of 250 tan 17 it would have to keep going in a straight line (so no gravity) for the entire distance.
So dy isn't 250 tan 17...it's 0 because it lands on the ground. But then we have nothing to input into the equations?
Sure you do. Try it.
dy:0 dx:250 v2^2=v1^2+2ad ?=?+2(-9.8)(0)
t:? t:? v2=v1+at ?=?+-9.8?
a:-9.8 a:0 d=v1(t)+1/2(a)(t)^2 0=?(?)+1/2(-9.8)(?)^2
vy1:? vx1:? d=v2(t)-1/2(a)(t)^2 0=?(?)-1/2(-9.8)(?)^2
vy2:? vx2:? d=(v1+v2/2)(t) 0= (?+?/2)(?)
I don't know what missing information I'm able to get from the two numbers given in the original question? I can't think of anything
Moderator note: Thread title changed to make it descriptive of the problem. Thread titles should not be overly generic! "Projectile motion" was far too generic.
whoops sorry
Since you have the launch angle, the vertical requirements (d=0) give you a relationship between the initial speed and the flight time.
The horizontal requirements give you another relationship between them.
Solve the simultaneous equations.
  • · Replies 19 ·
  • · Replies 21 ·
