Projectile Motion Jump Question
The discussion revolves around a projectile motion problem where a person jumps a horizontal distance of 8.9 meters with a takeoff speed of 15 m/s. Participants are trying to determine the angle of takeoff relative to the ground.
  • Participants discuss breaking the motion into horizontal and vertical components, questioning the interpretation of the jump distance as either horizontal or vertical. Various kinematic equations are suggested, and there are attempts to clarify the relationship between time, distance, and angle.
The conversation is active with multiple interpretations being explored regarding the jump's dimensions. Some participants have offered guidance on setting up equations based on the identified components of motion, while others seek clarification on the problem's parameters.
There is a noted ambiguity regarding whether the 8.9 meters refers to a vertical or horizontal jump, which has led to different approaches in the discussion. Participants are also considering the implications of using kinematic equations in this context.
yoyo16
A person jumps 8.9m. The person's takeoff speed was 15m/s. What is the angle relative to the ground at takeoff?
I found t using the kinematic formula to be 0.5s using the formula. d=vit+1/2at^2. Can someone tell explain to me what step to do next. Thanks
I assume the jump distance stated is horizontal only.
You can't use that kinematic formula straight out the way you did. You have to break it into two different directions. So you will have two formulas but three unknowns: t, dy, and θ. You get the 3rd equation using a trigonometric or geometric equation.
ummm, i attempted it so basically i used y=1/2at^2. so imagine you're at the peak of 8.9 meters, use that equation to calculate the amount of air time before reaching the air. after that use that t to plug in the vertical kinematic equation:
y= y(knot) + v(knot)t - 1/2at^2. plug 8.9 in. For v(knot) set it equals to v(knot)sin(theta). Then just find theta.
it's going to be parabolic path, therefore the time it takes to get into the air is the same as the time it takes to fall.
I'm assuming that he's jumping 8.9 vertically?so the math I just articulated is for vertical distance
Ummm...well you have to clarify is the person jumping 8.9m high (y direction) or 8.9m horizontally (x direction)?
I'm sorry about that. 8.9m was for the horizontal distance.
If someone could jump 8.9 m vertically, he would be the president for life of Phi Slamma Jamma.
Right, so then you can't use the equation the way you did.
Can you set up the 3 different equations?
ok it's pretty simple, you set up 2 equations of T(air time)
so the first one is t=(vsin(theta))/g and they other one is t=x/(vcos(theta))
set them equal to each other, plug v and x in and find theta, that's it
Edit: sry, for the first one just times it by 2 so t=2(whatever is there)
You'll need one more trigonometric identity equation to find theta.
Equation for trajectory says $$x = \frac {{v_{0}}^2\sin 2\theta}{g}$$
Plug in your unknowns from there.
Thanks guys for the help!
  • · Replies 22 ·
