Projectile motion: Two Balls and Building
9 replies · 2K views
yaniv arazi
1.[/B]
two balls are thrown vertically from two points on a building. at the bottom of the building ball 1 is thrown and from the roof ball 2 is thrown. ball one reaches its maximum height after three seconds and ball two after one second. after two seconds the balls cross paths. find the height of the building, the height of the meeting point, when they land and how long they are in the air for. if i am wrong please explain why. thank you in advance.air resistance is neglected.
2.
how do i prove the relationship
where h is the height v is velocity g is gravity and x is distance
height of the building=40 meters
ball one hits the ground after 6 seconds
ball two hits the ground after 4 seconds.
max height of ball one=85 meters
max height of ball two=45 meters[/B]
PeroK said:
All but one of the answers look right.
could tell me which one and why.thank you
PeroK said:
There one that is obviously incompatible with the others.
oh yes height of ball one thanks. do you understand question two because i do not
Moderator's note: Thread title changed to make it more descriptive of the problem posed.
PeroK said:
I don't know what question 2 means.
Question 2 is the question in which i ask how i prove the relationship its marked under question two. Again, thanks for the help sir!
Yes, I know, but I don't recognise that equation. Where did you find it?
$$x^2=\frac{2\ \cdot\ v^2}{g}\ \cdot\ h$$
x is the distance from where to where? v is the velocity of what? h is the height of what?
Edit: I think I can derive this formula under the assumption that x is the total distance traveled by a ball thrown vertically upward and then caught again at the point of the throw.
Hint: ##x=2h##
